![]() | Home > Puma (Tdci) > Defender PUMA = unstopable. Dune driving suggestion. |
Andrea, welcome ![]() AFAIK, the Puma does not have DSC, only ABS+TC ![]()
Get a Gmail account, which gives you access to PicasaWeb. Upload your images there and link them in your posts using the IMG tag. |
Andrea,
WE ARE WAITING YOUR PHOTOS!!!!!!!!! I'm not stay on my skin for that!!!!!!!!!!!!!!!!!!! ![]() ![]() ![]() ![]() IID Pro MV License |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
Or host them here (no new accounts needed) http://www.defender2.net/forum/topic123.html http://www.defender2.net/forum/topic124.html ![]() ![]() |
Yes, but no categorisation/geotagging ![]() |
Andrea Member Since: 02 Sep 2010 Location: South Africa Posts: 30 ![]() ![]() ![]() |
Naks, hi,
Sorry my error, it desables the ABS, so the system does not interupt your momentum by applying breaks at any stage!! Works a charm! I will put pics up as soon as i get them off the sticks!! |
Ok, makes sense. But I've never had to disable TC when driving in sand. As long as your tyre pressure is at 1.0 bar (or lower) and you choose the correct gear and maintain momentum, TC very rarely kicks in. See the following pics - TC did not even light up once when I climbed these dunes, and these were the small ones I climbed ![]() ![]() ![]() |
look tire pressures play a big part of the whole thing, I went to 0.9 bar, didnt want to go lower as we where towing the big trailers!! The part that i found that it helped a HUGE amount is when pulling off, the TC would come on instead of letting the cars tires gain momentum!! Disabling it gave the car a much easier pull off!!!
That looks like awesome fun, Is that the ATLANTIS dunes? I must say the Range Rover classic was better than all the cars in the sand, even better than the cruisers with both diffs locked!!! The dunes in the namib are relentless, the mintue you think you have a bit of an advantage you find yourself up to the axles!! Very fun! ![]() |
Yep, bucketloads of fun ![]() |
i dont agree about tyre pressures. you drop your pressure and you run a serious risk of popping the bead(s). I;ve never had any problem in sand keeping the pressures at normal. Put it this way, I'd rather get stuck than have to put a tyre back on.
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
On a few trips to North Africa, we also found, disabling the ABS/Tracs, was a big advantage in soft sand,
We had one hill, that the Puma would not climb,, High/low box, 2/3/4 gear, dropping the tyres pressures even further, all did not work,, but removing the ABS fuse, and she sailed up no problem,, The traction control,. was robbing the car of all its power California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
You cant have ever driven in soft sand then ![]() ![]() ![]()
Totally agree ![]() ![]() |
Braver than me Andrew,, 15 is about as low as i go on a 255/85 ![]() The beadlocks on the challenge truck go down to about 6psi, ![]() Main Brian James Trailer Dealer for South West UK |
As Andrew says ![]() ![]() |
13 in the morning increases to about 15 when the temperature gets up
