Home > Puma (Tdci) > Defender PUMA = unstopable. Dune driving suggestion.
Page 4 of 4 <1234
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
They call West Australians sand gropers, for good reason. Every one I know drops their tyre pressures in the dunes over here as on most rough surfaces. In most areas you are advised to drop the tyre pressures for the sake of yourself and other track users. I have found lowering pressures gets me off beaches when the higher pressures will not.
Allan
Post #47449 5th Dec 2010 1:32am
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
The reason SF et al strip their vehicles of everything is so that they can carry more guns/ammo/rations/equipment - what they don't want is loads of useless weight in the truck - unless they can use it to kill something
Post #47775 7th Dec 2010 10:53pm
Ninetenths
2007 Defender 110 Puma 2.4 XS CSW Java Black
True enough and also long range fuel tanks. The pink panthers were actually lowered to make them more covert. Pimped black '07 Puma
Equally Pimped Black Pick up Truck
Rollin deep
Post #47979 9th Dec 2010 5:07pm
siwady
United Arab Emirates 2012 Defender 110 Puma 2.2 SW Sumatra Black
Can anyone guide me on how to remove the ABS/TC fuse on my 2012 Defender.
Is it located under the passenger seat or the the box under the steering wheel.
Would appreciate a picture as I am not the technically inclined Razz
Post #426843 28th May 2015 10:46am
Page 4 of 4 <1234
