Home > Puma (Tdci) > 2.2 Oil Pressure Light - slow to go off?
Page 2 of 2 <12
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Yeah.......bloody progress eh?
Did wonder about it holding revs which demands learning to drive with backwards facing baseball cap! Can a reprogramme make it act like a diesel?
Otherwise the cabin much nicer, but climate control either hot or cold........give me a temperature knob and directional one back please.
Post #468934 3rd Nov 2015 8:06am
PaoloDefender
Italy 2013 Defender 90 Puma 2.2 CSW Tamar Blue
Hi all
In Italy there is a LR official recall for this problem
Just done on my def 2013 one week ago
Changed oil pump , some oil tube and the sump.
Post #469006 3rd Nov 2015 11:37am
Knot-yet
Have 2014 2.2 puma.
The oil pressure light goes out quickly, within 1 second when starting.
Mine was outside of the affected VIN range for the oil pump replacement.
I would recommend having a word with your dealer, 3seconds sounds quite slow.
Post #469108 3rd Nov 2015 6:08pm
Vmesch
Belgium
The oil pressure light is one thing (that goes out quickly... Mr. Green ), but what about the "warning" message on the odometer display? Is the message which is displayed for a couple of seconds just a "test message" or does it mean something when it's showing up at the engine start? That's my question.... Anyone to answer it Bow down Bow down Bow down ? puma 2.2 MY2013
[:O]===[O:]
Post #469193 3rd Nov 2015 9:32pm
alby
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
The oil service message that flashes up when the engine is first started and then disappears is the service timer. It's set to go off as a reminder at 12 month or 12000 mile intervals.
If the oil service message flashes up and then stays on it is an alert to advise that an oil change is due to interrupted DPF active regenerations.
If the regeneration cycle is interrupted more than 5(?) Times in a row then the message shows up and stays as an oil change is very strongly recommended due to the risk of diesel dilution of the engine oil during interrupted regeneration cycles.
Post #469211 3rd Nov 2015 10:16pm
chipmunk
Rang dealer who supplied first owner with mine and it's booked in to have pump changed under recall. They also do one of the inter cooler hoses apparently.
Does the engine go through the dpf cycle automatically?
Post #469264 4th Nov 2015 8:31am
alby
Mine seems to actively regenerate its DPF once a tank of fuel, around every 250miles of combined cycle driving. It doesn't seem to regenerate on long journeys though, the higher flow rate of exhaust gas and higher temperatures for sustained periods regenerate it passively.
I'm not entirely sure what the trigger is for an active regeneration of the DPF, I suspect its probably triggered by increasing differential pressure across the DPF, that would seem logical.
Post #469361 4th Nov 2015 2:03pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
After reading this thread a few weeks back, I noted that my oil light also takes approx. three seconds before going off. 54000 Km 2012 2.2. It wasnīt always that way, Iīm sure.
The oil pump recall was done in the spring, and after that, I remember the light going off quicker than it currently does.
Got me worried.
My oil service message was active, and I had a service lined up. The dealer said there is no connection between the oil service message and the reaction of the oil light. No inteigent electronics involved there! How refreshing!
After the service - new oil, the oil light took just as long to go off. The dealer offered to swap out the oil pressure sender with a new one - a two minute job. Job done, the oil light still takes its time, even after repeated switch off and restarts.
Dealer and I walk out to his own low mileage 110 2.2 demonstrator to see how quickly the oil light should go out.....and for the first time he discovers that even the oil light on his car takes three seconds to go out.
We laugh about it and decide there is nothing to worry about.....
Stephen 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #471851 12th Nov 2015 7:25am
chipmunk
That's reassuring for the future. Would like to know why the oil pump recall and specifics in cases of engine failure though.
Surely the Ford Transit is reliable otherwise it wouldn't be so successful?
Post #471882 12th Nov 2015 10:35am
Wild Card 90
I donīt know how to judge the oil pump issue. For quite a while they didnīt extend the recall to Eurpopean Defenders. Too few vehicle, and so even fewer cases of failure. Hereīs the thread...
http://www.defender2.net/forum/topic36247.html
My dealer hasnīt had an oil pump pack up, and did the recall on mine virtually on good will. I havenīt had any reason to doubt my current Defender, my first 2.2.
As is often said, when you see how the "white van man" drives his Transit, most privately owned Defenders are hardly being pushed to their limits, are they?
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #471892 12th Nov 2015 11:00am
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
I'm having mine serviced at a garage dealing with Ford and LandRover.
Years ago Ford started the Oil Pump recall for the Transit TDCi 2.2. My garage worked on this, too, although they did not inform me. Subsequently, Land Rover started their recall a few months ago. That's exactly when I got the information about the recall. I had my pump replaced a few weeks ago.
I did not realize any problem with the oil pressure light by now.
My garage is perfectly skilled since they "have been trained" on the Transit engines Laughing
They have some kind of special Ford tool allowing for quick and precise work.
The sump is glued to the engine block. That's why they wanted mine in for one day at least. Enough time for the glue to harden. According to their experience with the Transit.
According to them a stepwize recall has been essential because there have never been enough oil pumps available.
Well, have fun with your new oil pumps - Juka
Post #472837 15th Nov 2015 9:09pm
Cuthbert
So should those of us with recent model 2.2's now be expecting a new oil pump (or a shortened engine life)?
Post #472919 15th Nov 2015 11:14pm
chipmunk
Had my oil pump replaced two weeks ago...........oil light takes even longer to go out..!!!
Oil pressure switch faulty or it's normal?
Post #476844 27th Nov 2015 9:19pm
Page 2 of 2 <12
