Home > Maintenance & Modifications > heavy duty drive flanges |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 820 |
Fitted aftermarket standard replacement flanges to my 300tdi 110 earlier in the year and they are the same for front and rear (disc braked Salisbury) axle. Can't see any reason why the H/D items would be any different.
29th Oct 2015 11:53pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 791 |
Would the.easiest methodology check.not be to quickly take one off your other axle and try it?
Chris |
30th Oct 2015 8:32am |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
I've fitted a set to my 130. I think there is only two options with them are thick flanges for early type axle and thinner ones for the later type axle. The the thinner ones were the correct ones for my 95 Salisbury Axle.
1st Nov 2015 6:40am |
swissoak110 Member Since: 28 Aug 2015 Location: cleveland Posts: 17 |
Thanks for your help guys, ordered some just now.
1st Nov 2015 11:04am |
