Home > Maintenance & Modifications > heavy duty drive flanges
swissoak110
United Kingdom 2005 Defender 110 300 Tdi HT Fuji White
Has anyone fitted heavy duty drive flanges on a disc brake salisbury rear axle, I have terrafirma tf859 on the front of my 110 and want to fit them to the rear but just want to be sure they fit before spending my hard earned. Thanks.
Post #467653 29th Oct 2015 7:33pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Fitted aftermarket standard replacement flanges to my 300tdi 110 earlier in the year and they are the same for front and rear (disc braked Salisbury) axle. Can't see any reason why the H/D items would be any different.
Post #467732 29th Oct 2015 11:53pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Would the.easiest methodology check.not be to quickly take one off your other axle and try it?
Chris
Post #467755 30th Oct 2015 8:32am
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
I've fitted a set to my 130. I think there is only two options with them are thick flanges for early type axle and thinner ones for the later type axle. The the thinner ones were the correct ones for my 95 Salisbury Axle.
Post #468244 1st Nov 2015 6:40am
swissoak110
Thanks for your help guys, ordered some just now.
Post #468286 1st Nov 2015 11:04am
