Home > Td5 > TD5 Turbo oil return pipe gasget
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
Hi guys, after some advice on the gasket for the oil return pipe from the turbo, I fitted a new gasket yesterday as the other was leaking, fitted and went on a run for about 50 miles yesterday had no leaks, today on the way home from work the gasket has started leaking again. My question is, is there a difference in quality, not sure what make the gasket was as they had them on display in the shop.
Post #439146 20th Jul 2015 7:28pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Which type did you get? You can get Paper, Reinforced Paper and a metal one.
Post #439195 20th Jul 2015 10:15pm
tazmarkuk
Hi Taazzukcb the metal one
Post #439198 20th Jul 2015 10:19pm
taazzukcb
Hmm ... the metal one should do the job. I tried the paper and fibre jobs, all of which weeped a little. Put the metal one on, and whilst it weeped slightly to start with, after a few heat cycles, I nipped them up again and not had a drop since!
Post #439431 21st Jul 2015 9:21pm
munch90
If possible check the return pipe is clear as sometimes you can get a build up of carbon in the pipe causing a bit of back pressure and leaking
also is the flange on the pipe flat
Post #439438 21st Jul 2015 9:34pm
tazmarkuk
Hi taazzukcb yeah I tried to see if it would tighten up some more but no, asked around to day about another metal gasket, I payed 58p another dealer wanted £2.50, so I'm starting to wonder if their is a quality difference, both faces are clean.
Post #439446 21st Jul 2015 9:42pm
munch90
Clean , but are they flat , for metal gaskets they need to be 100% flat
Post #439449 21st Jul 2015 9:46pm
tazmarkuk
Update: I had issues of the oil return pipe not sealing with the turbo, well, it was nothing to with the gaskets or whether the surfaces were flat, it was the turbo. The turbo bearing was starting to collapse, thus pressurising the the oil system causing the leak. Turbo rebuilt, and after 200 miles now all is good.
Post #467015 27th Oct 2015 4:11pm
Welkman
thanks for posting this, I have a suspicion this could be happening on my defender as well. Is there any checks that are easily done to test for it pressurising?
Post #467023 27th Oct 2015 4:57pm
tazmarkuk
I don't know of any tests but someone may come along with an idea, the way I found out was a slight colour change in the aluiminium housing by the vanes which had become mat looking, the end float was still very minimal. Had the turbo checked by a specialist this confirmed my suspicions. You could check to see if any pressure is coming up through the dipstick tube. I had a little which has now gone.
Post #467025 27th Oct 2015 5:12pm
