![]() | Home > Maintenance & Modifications > Rear crossmember smoothing |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
I need to re finish the rear crossmember on my 90 before winter, while I was at it I thought about welding up the holes in it. That is where the surface corrosion starts where you can't get good paint coverage. Obviosly I can't weld them all up (jacking points, fuel tank cradle access holes, etc) but the ones for the bumperettes which I'll never fit, and the drop down tailgate hinge holes which I won't need I think welding them up to be a good solution.
Thoughts please? ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge Pictures of my 2002 crossmember. No rust but been well looked after 2002 110 td5 |
You'll find most of the muck inside the x-member comes from road spray underneath the vehicle,have a looksy under the wheelarch.At least the holes on the outside let you easily stick a hose/jetwash in there to clean the accumulated crap out it also lets you spray cavity wax in there.Yes, paint is always thinnest on the edge of a hole ,but that is easily cured with some quality paint and a gloss roller.Anyways,the next step after welding up the holes on a x-member is to chequer plate it
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
wouldnt bother. the corrosion always starts from the inside out. typically from where the chassis rails meet the crossmember.
Still haven't got used to this new bleeding phone
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 27th Oct 2015 1:10pm. Edited 1 time in total |
Hmm, seems like I'll have to stick to re-painting it every few years
Just paint it properly with good quality materials or get a bodyshop to do it and completely cover the back and inside with dinitrol or dynax ub and it should last a good long time. Ray
