Home > Maintenance & Modifications > Rear crossmember smoothing
grafty99
I need to re finish the rear crossmember on my 90 before winter, while I was at it I thought about welding up the holes in it. That is where the surface corrosion starts where you can't get good paint coverage. Obviosly I can't weld them all up (jacking points, fuel tank cradle access holes, etc) but the ones for the bumperettes which I'll never fit, and the drop down tailgate hinge holes which I won't need I think welding them up to be a good solution.
Thoughts please? Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #466596 26th Oct 2015 8:52am
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I personally wouldn't bother. Firstly you might change your mind about accessories and secondly, in my experience corrosion starts inside the crossmember. A bit of cavity wax should slow it down. Other areas it starts is on the leading edge behind the rear wheels where two sheets of metal join together
Mind you, it might actually be easier to say where it doesn't start rather than where it does Whistle 2002 110 td5
Post #466599 26th Oct 2015 9:43am
Jimb1978
Pictures of my 2002 crossmember. No rust but been well looked after 2002 110 td5
Post #466603 26th Oct 2015 9:50am
jimbob7
You'll find most of the muck inside the x-member comes from road spray underneath the vehicle,have a looksy under the wheelarch.At least the holes on the outside let you easily stick a hose/jetwash in there to clean the accumulated crap out it also lets you spray cavity wax in there.Yes, paint is always thinnest on the edge of a hole ,but that is easily cured with some quality paint and a gloss roller.Anyways,the next step after welding up the holes on a x-member is to chequer plate it Shocked ! Pov.spec,ftw. 2006, 110,TD5.
Post #466647 26th Oct 2015 12:15pm
mikeh501
wouldnt bother. the corrosion always starts from the inside out. typically from where the chassis rails meet the crossmember.
Post #466738 26th Oct 2015 5:46pm
grafty99
Still haven't got used to this new bleeding phone Embarassed double post sorry 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #466989 27th Oct 2015 2:09pm
grafty99
Hmm, seems like I'll have to stick to re-painting it every few years Sad 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #466990 27th Oct 2015 2:09pm
mk1collector
Just paint it properly with good quality materials or get a bodyshop to do it and completely cover the back and inside with dinitrol or dynax ub and it should last a good long time. Ray
My build thread
Post #467022 27th Oct 2015 4:57pm
