![]() | Home > Maintenance & Modifications > Bending Indicator stalks |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Yep done it a few times. Just take care and don't hold it at the very end, and hold on both hands, don't just pull it with one hand.
Andy |
LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198 ![]() ![]() ![]() |
I bent mine just last week after contemplating spending money on a low profile boss.
You just have to be careful to bend the stalk without causing any damage inside the switch. I found if you hold the stalk near the switch/base and then bend the stalk with your other hand, you can get the desired effect without affecting the functionality of the switch. If you break it, it's not my fault! ![]() 1989 Defender 90 Toyota Aygo & Honda FR-V |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
We use brake line bending pliers for the job. No problem WANTED:
SII or SIII in max 1.5k |
Shouldn't have such stumpy digits!
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
I put a post up with pics but I can't find it now!
I just got 2 pairs of grips and gently bent them outwards, it doesn't take much effort to bend them so be careful, very easy to do and makes it much easier if you've fitted a Momo or similar, use something soft in the jaws of the grips so it doesn't mark the rubber, or just peel the rubber back. |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
I have LOOOONg fingers but it's just not a natural distance...feels weird! ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Thanks for the replies by the way, will try using a pair of grips, maybe with some chammy between the jaws and the stalk to prevent damage. 2016 D4 HSE
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
Give Uri Geller a call
He's shot off back to whence he came and I reckon he took his spoon with him due to the notice placed on it? ![]() ![]() http://www.getreading.co.uk/news/reading-b...t-10268065 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
Its gone
![]() A giant red spoon sculpture unveiled by TV illusionist Uri Geller as a parting gift to the Berkshire village of Sonning where he has lived for 35 years has been removed. The steel statue in the shape of a bent spoon had been placed on a large tree stump in Sonning earlier this month. However no planning permission was given for the sculpture to be erected. It is not clear who has taken the sculpture down, or why. However ![]() The mystery surrounding the controversial bent spoon sculpture donated to Sonning by Uri Geller has been solved. His spokesman Kevin Lewis says : “I’ve now managed to get hold of Uri and there is an explanation for the missing spoon sculpture. “Uri had a very strong feeling that retrospective planning was going to be denied, “So the decision has been made to remove the spoon from Sonning on Thames and flown to Jerusalem, to be presented as a symbol of peace in order to aid Uri in his efforts in that regard. ![]() ![]() http://www.youtube.com/user/conwy1 |
