![]() | Home > Td5 > Trouble starting TD5 |
Could be a poor earth under the drivers seat, worth checking out the spade connections on the relays under there whilst you're in there as well.
Podrob Member Since: 20 May 2012 Location: Co Derry, N Ireland Posts: 31 ![]() ![]() ![]() |
Thanks, will have a look. Think the spades should be ok. Had that problem a few years ago and sorted it. I seem to have had most of the common TD5 issues.
Whilst you're checking round have a look at the trigger wire on the starter motor for clean contact as well
This appeared to be the problem with oil leaking down the back of the rocker cover not helping things. I checked the earth under the drivers seat which was ok but loosened it a bit to see what would happen. Sure enough it would not start but turned over ok with the loose earth. My problem was that it would not turn over. Thanks for the suggestion. I cleaned up all the contacts but am in two minds whether to cover them in Copper grease.
My starting problem is back, intermittent problem with starter not turning over, behaves like the battery is flat especially when the fuel pump is running but eventually starts normally. So far I have cleaned the both starter contacts, earth under the drivers seat, battery and alternator ok, relays under drivers seat all ok, any ideas ?
You just get a click when you turn the key? Sometimes it will catch when you have the impression that you've had the key in the start position for longer than usual...... This points to the starter solonoid in need of some attention. You can buy a new solonoid kit off ebay for less than a tenner which gives you new copper contacts and plunger which will sort you out.
This can be done from underneath without taking the starter motor off but if it's your first time it would be advisable to take the motor off and do it on the bench ![]() |
I don't get anything when turning the key, no click, then after a few attempts and when the fuel pump has stopped it starts normally. Do you think that is still the solenoid. Saw those kits a while ago, no harm in giving that a go. Would rather sort it from above than below. Thanks for the advice.
When my starter terminals were starting to go there would be no click or anything then after a few try's it would start so I'd say that's definitely the problem. It's much easier to take the starter off from underneath though and swapping the terminals over is an easy job
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Raywin Member Since: 27 Feb 2015 Location: North Yorkshire Posts: 48 ![]() ![]() ![]() |
Does the fuel pump whine when you turn on the ignition, then go quiet? If so have you looked at the fuel system? You mention oil running down the engine, are you sure it's not diesel.
My defender just failed the MOT on a fuel leak at the back of the engine drivers side, the pipes into the fuel pressure regulator were leaking and they allow air into the system when the engine is standing this makes it a pig to start, if I turned on the ignition the pump in the tank whined for a while and when it stopped the it would start ok. It's also worth changing the bleed valve on the diesel filter, only cost a few pounds and helps the system purge itself. |
Thanks for the suggestion re the fuel system, fuel pump behaving normally (at least as it always did). The oil is engine oil rather than diesel, think it is the rocker cover half moon. Fuel pressure regulator was replaced when I bought it and looks ok. Think the issue is with the starter as it does not turn over rather than turns over but does not start.
I got the starter off much easier than expected for the top bolt. Used 3/8 15 mm socket universal joint and 3 of the longer extension bars down through space between in let ports for two rear most cylinders and did the lower two bolts from under. My problem wo is that the contacts don't look right on the kit supplied. Are there different types of these contacts. The smaller of the two contacts looks ok but the larger one is significantly different. Will contact the supplier but was wondering if anyone had similar issues. The plunger supplied was ok so I just fitted that in the mean time, seems to work. Will post a couple of pictures of the contacts when on a pc. Thanks for all the suggestions, the solenoid does look to be the most likely issue. |
do you think it is the startmotor
![]() http://timtrott.co.uk/defender-td5-starter-motor-removal/ http://www.aulro.com/afvb/projects-tutoria...r-diy.html |
Thanks for the info. Yes am fairly sure it is the starter. It would be an easy enough fix if I had the right contacts
