Home > Maintenance & Modifications > LED Side lights
Page 1 of 3 123>
StephenO
LED Side lights
Hi
I have a D90 300tdi and recently upgraded the front lights and fitted 110 night breakers. I've also added LED wedges in the main headlamp and looking to fit Side and Rear Tail/Stop LEDS. Having purchased 2 sets now that are meant to be compatible none of them seem to work.
R5W & P21 fittings but no joy?
Anyone got any ideas?
Stephen Thumbs Up 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #464522 18th Oct 2015 11:41pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
Hi Stephen,
The issue is that the bulbs are diodes and land rover in their wisdom wired the lights backwards (Earth in the centre) to get LED 'bulbs' to work you will need to swap the wires around.
Jason
Post #464524 18th Oct 2015 11:49pm
StephenO
Thanks Jason, I'll give that a go Thumbs Up 2007 Defender Puma Tonga Green
Post #464746 19th Oct 2015 8:03pm
StephenO
Jason,
Worked a treat, wired one in tonight. What a difference cheers Thumbs Up
Post #465038 20th Oct 2015 7:34pm
mk1collector
Led bulbs aren't road legal though Whistle Ray
My build thread
Post #465044 20th Oct 2015 7:47pm
StephenO
Don't think LED side lights are illegal. If they are then my D3 has been illegal for a few years and passed a number of MOT without question 2007 Defender Puma Tonga Green
Post #465058 20th Oct 2015 8:13pm
JAY BOY
Wales
My FFRR has all LED lights as standard with exception of head lights Whistle
Post #465060 20th Oct 2015 8:16pm
LED lights that are factory 'E' marked on the lenses such as Wipac or RDX sidelights are legal.
LED headlights are legal again if E marked units.
Fitting LED fixtures into Crystal headlights or other aux lights is illegal.
Post #465063 20th Oct 2015 8:22pm
StephenO
So, my Wipac crystal headlamps are "e" marked so I can't put 501 LED wedges in them (legally)? 2007 Defender Puma Tonga Green
Post #465073 20th Oct 2015 8:37pm
Cupboard
Paging Brendan...
Seriously though, it's not the MOT's job to check that sort of thing.
Post #465083 20th Oct 2015 8:47pm
StephenO
Anyways, I like them, the other side will be fitted tomorrow and I'll take my chances Wink 2007 Defender Puma Tonga Green
Post #465094 20th Oct 2015 9:07pm
No because they are designed for incandescent standard bulbs only and not tested for conformity.
If you want LED headlights your talking Speakers or Nolden to be legal.
Post #465109 20th Oct 2015 10:12pm
mk1collector
As said mot people don't check but putting an led bulb in a light made for normal bulbs is illegal and if you get pulled at one of the vosa stop checks you may get in trouble. Ray
My build thread
Post #465111 20th Oct 2015 10:12pm
StephenO
Thumbs Up Thumbs Up 2007 Defender Puma Tonga Green
Post #465115 20th Oct 2015 10:14pm
JWL
I took the decision to put leds in my sidelights, both in the existing lenses and also in the pilot lights in the Chrystal headlights. I am prepared to take the consequences but not after arguing that my Defender is better off being well lit as I have it now than the poor attempt that is standard.
Off
On
Post #465131 20th Oct 2015 10:40pm
Page 1 of 3 123>
