Home > Puma (Tdci) > Oil again out the bellhousing
CapeLandy
South Africa
Last time it was clutch fluid from the slave cylinder but the level is still full this time.
Any way to tell whether gearbox or engine oil?
On the series you could definitely smell between engine and EP90 but not so sure on the new one.
Anyway - one month before end of warranty - back she goes again Big Cry
Post #46436 26th Nov 2010 8:07pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Cape my slave has leaked for over 6 months .... still only lost 10mil of fluid the only reason i knew it was leaking was that it was empty and the clutch went soft ...then i refilled it. its took 6 months to lose 10 mil ......if its still under warranty get it in and get it fixed as the dealer wanted Ģ700+ to fix it ? .... Independent wanted Ģ270 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #46452 26th Nov 2010 11:03pm
MK
I guess engine oil should be darker, diesel smelling and thinner. Puma 110" SW
Post #46467 27th Nov 2010 3:50am
CapeLandy
South Africa
It's either gearbox or engine oil in my opinion
Post #46468 27th Nov 2010 4:58am
MK
I agree. Why donīt you collect a bit a and compare with oil from the dipstick at room temp?
Im striping down mine starting next monday to check at the clutch assy. Puma 110" SW
Post #46475 27th Nov 2010 9:58am
CapeLandy
South Africa
Has your warranty expired?
Are you having to replace a suspected clutch again?
Post #46499 27th Nov 2010 5:51pm
MK
sort of. Yes, I want to check a clicking noise and Iīm really sick of the customer service (and all services). Puma 110" SW
Post #46511 27th Nov 2010 9:51pm
CapeLandy
South Africa
Update
dealer says crank seal weeping.
Told me they have cleaned it and I should ride for a few weeks and see again Evil or Very Mad
(Warranty Expires end month)
Told them they were mad - keep the vehicle till the crank seal is replaced - end of conversation.
As an aside - I hope the incident where I accidentally ill fitted my air filter and sucked in a fair amount of dust into the motor is not the cause of the seal failure Shocked
I did change the oil and filters when I noticed my error
Post #47029 2nd Dec 2010 7:48am
MK
Sometimes twisted cranckshafts break seals. Hope it is not.
I agree. You need nurse hands to fir the upper cover from the air filter (Fordy). Puma 110" SW
Post #47040 2nd Dec 2010 10:15am
CapeLandy
South Africa
Seal ordered and booked in 3 days before I travel up country.
Post #47085 2nd Dec 2010 2:43pm
