Home > In Car Electronics > Focal Subwoofer - Location?
jonnyboy
United Kingdom 2005 Defender 90 Td5 XS CSW Tonga Green
Bought a Focal subwoofer to go in the new 110. Reading around seems like most have fitted them under the rear seats.
Has anyone fitted them anywhere else. Was thinking today if under the cubby would work? Would need to sign some kind of frame to raise the cubby up
Any pictures/advice appreciated
Post #460727 5th Oct 2015 7:06pm
Some also use the the rear of chubby box.
Post #460731 5th Oct 2015 7:17pm
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
So I have a Focal IBus fitted and like you was unsure as to where the best place to fit it was, however i have now fitted it on the rear box arch snug against the side. It has a purpose made box which sits over it for protection and is Dyna matted and carpeted. Sounds awesome without any reverberation. Now if only I could get the rear speakers to work that are plugged into it!! Photo to follow.
Post #460733 5th Oct 2015 7:20pm
jonnyboy
Steve - Surely its too big for the rear of the cubby. The Alpines, Kenwoods etc seem to fit there but this is much bigger
Charlie - look forward to the photo Thumbs Up
Post #460738 5th Oct 2015 7:26pm
What sort of dimensions are we talking?
Unless we are talking REALLY big even if it is larger than the chubby rear you can likely make a mounting plate / board.
But yes, depends on size though..
Post #460746 5th Oct 2015 7:39pm
jonnyboy
The Focal unit is much bigger than the, say, commonly fit Alpine unit.
The Focal is 344mm x 250mm
The Alpine SWE 1200 is 280mm x 226mm and is a good fit on the rear of the cubby
Post #460755 5th Oct 2015 7:56pm
jonnyboy
So after a bit of playing this afternoon, think I'm going to go for mounting it below the Cubby Box. Going to make an open ended MDF box, bolt that to the floor, install the subwoofer in that, and re-install the cubby box on that. Box will be about 4" high, open front and back for ventilation and maybe painted black/trimmed in vinyl
Anyone see any flaws in that?
Post #462297 11th Oct 2015 4:28pm
Sounds good. What gap between the chubby bottom and sub grille p?
Post #462345 11th Oct 2015 7:27pm
jonnyboy
About 1". Figure its designed to go under a seat.....
Post #462416 11th Oct 2015 10:30pm
Yeah, that should be fine. Any less though I wouldn't go for.
It should transfer bass to body quite well. Thumbs Up
Post #462428 11th Oct 2015 11:13pm
Edzi
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Alaska White
Would love to see some pictures please Smile
Post #485846 27th Dec 2015 3:06pm
jonnyboy
Edzi
Went for under the rear seat in the end....
http://www.defender2.net/forum/topic41292.html
Post #485858 27th Dec 2015 4:30pm
Edzi
Thanks Smile
Post #485953 27th Dec 2015 9:07pm
