![]() | Home > Maintenance & Modifications > There's a hole in my Defender... |
The lovely and wonderful previous owner (
![]() ![]() Click image to enlarge They did have a bit of steel badly riveted on top of them which looked silly, cut things that lay on top of them and were generally annoying. Is there a better way of doing it that will give me a reasonably flush surface to put stuff on top? Preferable cheap and easy ![]() Also are three runners along the load bed of a 110 HT standard? I've taken them out because they were really tatty and am replacing them with some cargo rail from Mud. |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
grommets? 2002 110 td5
Put a piece of ally underneath and rivet from the top? But make sur you seal it. Ray
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 ![]() ![]() |
It must have been me as the previous owner im going to cut a plug hole into the rear tub of my double cab, I get a paddling pool when it rains. The tailgate seals cant be genuine parts as they work to well
![]() As said id put a grommet in it ![]() ![]() Click image to enlarge |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
I have used this technique many times to effect "invisible" repairs in wings, etc., simple and effective. You can use Araldite (pref not the rapid one) and a heat source (hot air paint stripper, fan heater, SWMBO's hairdryer if she's out, etc) to cure the epoxy in minutes to full strength. I've just realised that some of the repairs on my S1s done this way have been on for more than 2/3rds the life of the vehicle! Gulp! |
Thanks
![]() So I need to get myself some slow cure epoxy, a bit of aluminium sheet and borrow my girlfriends hair drier she seems to have installed in my house. Then just clean off all the crud from underneath ![]() |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Just make sure you put the hair dryer back where you found it.........
![]() Wanted, Forward Control Anything considered. |
or just bung a grommet in it 2002 110 td5 |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2956 ![]() ![]() |
You could use a round metal or plastic conduit box cover
For the last you mention there, two of these maybe? The good thing is they will float when water fills the space through the smaller holes. ![]() ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
^^^^have you got the part number for the above item? ^^^^
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
I think it was either a heater or a generator, there was an exhaust that I removed underneath one of them.
The rear door seal was in a terrible way which would make sense with a generator. |
