Home > Td5 > Gearbox soundproofing
Page 2 of 3 <123>
mk1collector
Every little helps and disco 2s are a lot quieter than defenders Ray
My build thread
Post #457866 24th Sep 2015 8:57pm
grafty99
Just bought one to fit this weekend hopefully Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #457902 24th Sep 2015 10:33pm
mk1collector
They go in from the top so it's an air box and bracket out job Ray
My build thread
Post #457907 24th Sep 2015 11:22pm
g-mack
shame they don't fit tdi bell housing , if i want something think it will hv to be noise killer bell housing blanket @ £100+ My 109 thread
my youtube channel
Post #457913 24th Sep 2015 11:39pm
grafty99
Cheers Ray, I looked at you excellent build thread Thumbs Up I had the air box out the other week so it should pop out pretty easily this time Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #457932 25th Sep 2015 7:52am
mk1collector
Embarassed thank you Thumbs Up it's still a bit of wiggle with the air box out but not too bad Thumbs Up Ray
My build thread
Post #457997 25th Sep 2015 3:05pm
isacs
I'll get one ordered and give it a whirl
Post #458319 27th Sep 2015 9:20am
grafty99
Well I fitted mine yesterday whilst giving it a quick service before going away this weekend. I haven't driven it so can't comment on noise reduction yet. Can't be worse though Laughing
Did you notice any improvement Ray? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #459449 1st Oct 2015 8:08am
mk1collector
I had the gearbox tunnel in and out at the time I put the disco cover in so as I'd driven without the tunnel on for a day or two the sound difference was amazing!!! But it could have just been that it was much quieter with the tunnel back on Rolling with laughter Ray
My build thread
Post #459624 1st Oct 2015 6:37pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Just done this on my current project...trying out the STP mat as its thicker than dynamat and easier to fit.
N.
Post #459677 1st Oct 2015 9:02pm
roel
I also drove a few miles without the gearbox cover to find an oil leak, I can confirm it is a bit noisy. Mr. Green
Does that extra bit over the gearbox cover help? As there is already a nice piece off foam in the cover itself. The bulkhead and floors are not lined with foam so I think that is a better place to attack. Roel
2003 90 Td5 (2009-now)
Post #459759 2nd Oct 2015 8:45am
grafty99
Well I can't decide if it's made a difference or not. However I did notice a breeze from the transmission tunnel whilst going down the motorway so I might not have a sealed tunnel. I shall report back when I've had the carpet out tomorrow Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #459996 3rd Oct 2015 12:08am
Telshe
England 2004 Defender 90 Td5 XS CSW Cairns Blue
What fixings are needed
I have just ordered a gearbox cover to help with the gearbox noise for my 90. What fixings are needed ?.
Regards Telshe
Post #460795 5th Oct 2015 9:22pm
jabber
United States 1986 Defender 110 Other SW Oslo Blue
I put the disco gearbox cover on, while I had the trans and xfer case out (clutch, flywheel, etc... and 1.2 xfer case). The cover helps a bit with the sound and heat in the general area. All the "dynomat", heat insulation (http://www.lobucrod.com/), and stall matting coupled with the 1.2 xfer box... I can hold a conversation with my daughter at 70mph...
The cover just sits on top of the bellhousing... No fixings needed.
Post #461368 7th Oct 2015 7:20pm
Telshe
Many thanks jabber, lm just about to go out and do it.
Many thanks telshe
Post #461483 8th Oct 2015 8:47am
Page 2 of 3 <123>
