Home > Td5 > Gearbox soundproofing |
Every little helps and disco 2s are a lot quieter than defenders Ray
24th Sep 2015 7:57pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Just bought one to fit this weekend hopefully 2002 90 Td5 Station Wagon
24th Sep 2015 9:33pm |
They go in from the top so it's an air box and bracket out job Ray
24th Sep 2015 10:22pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
shame they don't fit tdi bell housing , if i want something think it will hv to be noise killer bell housing blanket @ £100+ My 109 thread
my youtube channel |
24th Sep 2015 10:39pm |
Cheers Ray, I looked at you excellent build thread I had the air box out the other week so it should pop out pretty easily this time 2002 90 Td5 Station Wagon
25th Sep 2015 6:52am |
thank you it's still a bit of wiggle with the air box out but not too bad Ray
25th Sep 2015 2:05pm |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 |
I'll get one ordered and give it a whirl
27th Sep 2015 8:20am |
Well I fitted mine yesterday whilst giving it a quick service before going away this weekend. I haven't driven it so can't comment on noise reduction yet. Can't be worse though
Did you notice any improvement Ray? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
1st Oct 2015 7:08am |
I had the gearbox tunnel in and out at the time I put the disco cover in so as I'd driven without the tunnel on for a day or two the sound difference was amazing!!! But it could have just been that it was much quieter with the tunnel back on Ray
1st Oct 2015 5:37pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I also drove a few miles without the gearbox cover to find an oil leak, I can confirm it is a bit noisy. Does that extra bit over the gearbox cover help? As there is already a nice piece off foam in the cover itself. The bulkhead and floors are not lined with foam so I think that is a better place to attack. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
2nd Oct 2015 7:45am |
Well I can't decide if it's made a difference or not. However I did notice a breeze from the transmission tunnel whilst going down the motorway so I might not have a sealed tunnel. I shall report back when I've had the carpet out tomorrow 2002 90 Td5 Station Wagon
2nd Oct 2015 11:08pm |
Telshe Member Since: 02 Jul 2015 Location: West Oxford. Posts: 49 |
I have just ordered a gearbox cover to help with the gearbox noise for my 90. What fixings are needed ?.
Regards Telshe |
5th Oct 2015 8:22pm |
jabber Member Since: 10 Jun 2009 Location: Colorado Posts: 17 |
I put the disco gearbox cover on, while I had the trans and xfer case out (clutch, flywheel, etc... and 1.2 xfer case). The cover helps a bit with the sound and heat in the general area. All the "dynomat", heat insulation (http://www.lobucrod.com/), and stall matting coupled with the 1.2 xfer box... I can hold a conversation with my daughter at 70mph...
The cover just sits on top of the bellhousing... No fixings needed. |
7th Oct 2015 6:20pm |
Many thanks jabber, lm just about to go out and do it.
Many thanks telshe |
8th Oct 2015 7:47am |
