![]() | Home > Td5 > Gearbox soundproofing |
Every little helps and disco 2s are a lot quieter than defenders Ray
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Just bought one to fit this weekend hopefully
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
They go in from the top so it's an air box and bracket out job Ray
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
shame they don't fit tdi bell housing , if i want something think it will hv to be noise killer bell housing blanket @ �100+ My 109 thread
my youtube channel |
Cheers Ray, I looked at you excellent build thread
![]() ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
![]() ![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
I'll get one ordered and give it a whirl
Well I fitted mine yesterday whilst giving it a quick service before going away this weekend. I haven't driven it so can't comment on noise reduction yet. Can't be worse though
![]() Did you notice any improvement Ray? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I had the gearbox tunnel in and out at the time I put the disco cover in so as I'd driven without the tunnel on for a day or two the sound difference was amazing!!! But it could have just been that it was much quieter with the tunnel back on
I also drove a few miles without the gearbox cover to find an oil leak, I can confirm it is a bit noisy. ![]() Does that extra bit over the gearbox cover help? As there is already a nice piece off foam in the cover itself. The bulkhead and floors are not lined with foam so I think that is a better place to attack. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Well I can't decide if it's made a difference or not. However I did notice a breeze from the transmission tunnel whilst going down the motorway so I might not have a sealed tunnel. I shall report back when I've had the carpet out tomorrow
Telshe Member Since: 02 Jul 2015 Location: West Oxford. Posts: 49 ![]() ![]() ![]() |
I have just ordered a gearbox cover to help with the gearbox noise for my 90. What fixings are needed ?.
Regards Telshe |
jabber Member Since: 10 Jun 2009 Location: Colorado Posts: 17 ![]() ![]() ![]() |
I put the disco gearbox cover on, while I had the trans and xfer case out (clutch, flywheel, etc... and 1.2 xfer case). The cover helps a bit with the sound and heat in the general area. All the "dynomat", heat insulation (http://www.lobucrod.com/), and stall matting coupled with the 1.2 xfer box... I can hold a conversation with my daughter at 70mph...
The cover just sits on top of the bellhousing... No fixings needed. |
Many thanks jabber, lm just about to go out and do it.
Many thanks telshe |
