Home > Maintenance & Modifications > Another Webasto Thread- but with a Tdi
Page 3 of 5 <12345>
shaggydog
It just preheats the coolant which in turn heats the block but you can do wire it in such a way that it also starts the heater motor so it warms the block and the cabin- albeit slower than if you were just heating the block as your loosing heat via the heater matrix.
I chose this one because I reckoned that having less wear on the engine by having a warm block would be better in the long run and the heater would still be warmer quicker than starting from stone cold.
Hope that answers your question Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #458855 28th Sep 2015 9:59pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Top answer Thumbs Up
But she still says no! Sad 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #458955 29th Sep 2015 12:21pm
shaggydog
Give it a few weeks till it gets colder, then suggest it again Whistle Laughing Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #458957 29th Sep 2015 12:27pm
shaggydog
Quick question regarding exhausts...
Does anyone have any reason as to why I could/should not route the exhaust down the wheel arch on the wheel side?
Or should I route it on the inside of the engine bay and out down the chassis rail to the floor?
I'm trying to work out what parts I'm going to need for exhausts weather to go solid pipe or flexipipe. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #459083 29th Sep 2015 7:24pm
I fitted mine down the side of the wheel arch .. No issues
Key thing with diesel heaters is to run them regularly all year round
Mines been good as gold for 4 years
Post #459085 29th Sep 2015 7:28pm
shaggydog
I don't suppose you have a picture of your set up for comparison do you?
And yes I'm a big fan of use it or loose it! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #459093 29th Sep 2015 7:37pm
Can do you a photo but will be tomorrow now as the woodburner is now lit
Post #459098 29th Sep 2015 7:58pm
shaggydog
Thanks for that Thumbs Up
And yes no worries, ours may well be lit soon! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #459114 29th Sep 2015 8:18pm
jst
it wont over heat the engine, you can run it in conjunction with engine but will be different flow rates
for your application you wont need the one way valve if ont feel
i haev had three of them in td5 and pumas all worked really well Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #459816 2nd Oct 2015 12:05pm
shaggydog
Thanks for that JST Thumbs Up
I do have picture of it sort of in place but its on my phone and wont come off without a cable which is at home Big Cry
I must say I'm really looking forward to getting it sorted and fitted but at the moment the head is the biggest priority Shocked Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #459818 2nd Oct 2015 12:19pm
shaggydog
Not updated this in a while but have got a fair amount done!
Firstly got the water pump for the webasto fitted and the webasto mounted onto a bracket, combined with the repositioned washer bottle.
You will see the water pump attached under the heater box (its a genuine webasto part but not as usually fitted and I cant see the logic in spending another £70 odd quid on a pump to replace a pump?
Also got the exhaust pipework loosely assembled, though it does read a bit like a Dr.Seuss book.
Out from the webasto and round a bend, over the intake then down a bend....
Down past the coolant pipe, next to the foot box, then under the flap and into the wheel arch....
Then out past the mudflap and along the outrigger, with a gentle bend...
Out to the atmosphere!
What do we think?
Also got the wiring progressing and the fuel system coming along. Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #467692 29th Oct 2015 9:33pm
Rosco
Top job. Any estimated time on its first test run? 2007 - Stornoway Grey 90 XS SW - Gone
Post #467720 29th Oct 2015 10:44pm
shaggydog
I'm hoping to have a good bash at it this weekend Thumbs Up
It has had a bench run which proves it works just need to repeat that while in place!
Fingers crossed! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #467721 29th Oct 2015 10:50pm
Mo Murphy
Does it work then, shaggydog ?
50 Shades of Pennine Grey
Post #470079 6th Nov 2015 12:22pm
shaggydog
Not sure Mo....
I haven't been able to sort the fuel line yet or the electrics to it but plumbing wise all seems happy and well Very Happy
I have actually now got the whole truck running so i have left it for now to allow running in the new head and any snagging but i am hoping now that 90% of it is done the final bits should be achievable in an afternoon.
Problem is Miss Shaggydogs 110 is require very urgent attention to its braking system on the front so that has been the priority for this week, thanks the rain though not much has happened on ether trucks Big Cry
But hey ho, were getting there.
One thing I have noticed since putting it all back together is that the 200Tdi heater blower is utter pants compared to the Td5 one. I will have to put a voltmeter on the plug and see what reading I'm getting as it feels like its hardly on at all on full blast despite all the flaps being correctly positioned. Bit pointless having a lovely warm engine block if the heater is too asthmatic to do anything with it Evil or Very Mad Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #470085 6th Nov 2015 12:45pm
Page 3 of 5 <12345>
