Home > Maintenance & Modifications > Another Webasto Thread- but with a Tdi
Page 5 of 5 <12345
shaggydog
Embarassed
Ran it before coming home from work today - worked beautifully absolutely over the moon with it.
Just need to build my trust up with it a bit Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #476815 27th Nov 2015 7:56pm
shaggydog
Hi Guys,
Quick question with this....
My Exhaust end looks like this currently.
Can I drive with it running with this set-up or will that cause untold chaos?
What do you think? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #477389 29th Nov 2015 4:50pm
Retroanaconda
I'd probably site it somewhere else - one muddy field/lane and that'll be clogged with mud stuck up against the outrigger.
Post #477398 29th Nov 2015 5:14pm
VeeTee
Netherlands
I would extend it a bit with fexible exhaust hose and point it backwards under the outrigger. Cheers, Vincent
MySite
Post #477406 29th Nov 2015 5:23pm
shaggydog
If I was to just do a 90' bend straight down and then a piece of pipe down to just below the bottom of the outrigger?
Can you run the heater while driving?
I assume you can?
Reason being is that once I get going the temperature falls quite quickly as I drive it cools the engine down again so I am thinking of keeping it running until the engine can sustain its heating? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #477434 29th Nov 2015 6:48pm
VeeTee
Netherlands
I guess you can (but I'm not sure about that) - according to the Installation Manual the heater wil adjust its heat output according the coolant temperature between 77 - 79 C, if the coolant gets hotter it will shut down. Cheers, Vincent
MySite
Post #477447 29th Nov 2015 7:19pm
shaggydog
It does go into maintain mode when it gets to temperature and then will shut down if it gets too hot.
Problem I have is I start it running in the morning, it gets up to running temperature so I turn it off, then start the engine and drive to work but in that time the engine cools down to below running temperature.
I'm guessing a rad muff could solve this? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #477449 29th Nov 2015 7:22pm
VeeTee
Netherlands
Why not try it, let it run while you start the engine and drive to work?
And yes - a muff would definetly help. i always put it on when temperature drops. Cheers, Vincent
MySite
Post #477460 29th Nov 2015 7:46pm
Retroanaconda
Why is the engine cooling down? Without the coolant heater it would start to warm up once running and driving until it settled at running temperature so why is it doing the opposite when it has been pre-heated?
Is your viscous fan seized? Thermostat known good?
Post #477493 29th Nov 2015 9:06pm
Page 5 of 5 <12345
