Home > My Defender > Bretto's new 110 wagon
Page 5 of 5 <12345
BRE770
Australia 2013 Defender 110 Puma 2.2 SW Corris Grey
Photobucket can eat a dick, I'll fix the pic links tomorrow when I get a chance
Post #355863 5th Sep 2014 11:03am
BRE770
Links Fixed!!! Mr. Green
Post #355970 5th Sep 2014 9:25pm
BRE770
Haven't been on here in ages but have done a fair bit to the chariot in the past few months so time for an update. This is going to be a long one!
Chucked a Runva 11XP winch on it.
Pulled the winch gearbox apart to grease it up before fitting
Chucked an 80 channel UHF in it. went with a UNIDEN UH8080NB with Police, Fire and Ambulance channels preprogrammed
Replaced the centre silencer with a Terrafirma unit
And fitted a Scangauge
Then took it down to Sundown National Park for a couple of days of fun. taking the unmaintained track to get into Sundown it takes around 3 and a half hours to do 17km. Awesome fun.
the side steps copped a bit of a hiding on this trip, will get rocksliders for it one day
Couple of videos of it in action
http://youtu.be/o5gqx5Z7_xw
http://youtu.be/fl-Uh-FxWr4
http://youtu.be/mZZawe764Ho
Then I got a Safari snorkel for Christmas
I reckon I found the limits of the factory All Terrains so couple of days ago on went a set of Muddies.
285 75r16 Federal Couragia MT's on 16x8 Dynamic zero offset rims.
And thats where its at at the moment. Next on the list is fit the APT front and rear diff guards I got for christmas and that will probably be it for a while. Maybe a couple of inches of lift some time down the track.
Post #389634 18th Jan 2015 4:02am
Thanks for sharing. I've seen this on AULRO, right? Though not been on for a while, I'll have to catch up.
Post #389649 18th Jan 2015 8:07am
BRE770
Yeah had a thread on aulro, then they bought in the compulsory subscription thing, so haven't been on there for a while. Might get around to paying for a subscription and updating the thread one day.
Post #389654 18th Jan 2015 8:23am
As an occasional visitor, I won't be back on there. I'm not saying it's wrong, but if 6000 regular people subscribe, that's $9,000 a month for the host Shocked
Martin (Founder of this site) could be ordering another new Defender Cool
Post #389667 18th Jan 2015 8:49am
BRE770
Quick mud run this morning, tyres performed exceptionally well. Still at road pressures.
Post #390853 21st Jan 2015 2:31am
BRE770
Haven't been on here in a while. Quite a bit has happened over the last 6 months.
49" Led light bar on the roof rack and a couple of LED work lights
Blacked out the bonnet badges, grille and headlight surrounds with plasti-dip
Then the side steps were looking a bit sad (Drivers side was folded up nearly touching the sill) so I built a set of sill replacement sliders
Then Terrafirma +2" prosports, APT shock turrets, Dobinson coils and TomWoods double cardin front prop shaft. Also did the holey bush mod to the front radius arms while I was in there.
Replaced the rear sliding windows with aluminium gullwings.
Then came APT front and rear diff guards
and that brings this thread up to date, this is how it sits now
Front end dislocated
Post #458582 28th Sep 2015 4:47am
BRE770
So a bit has happened to this lately, replaced the tired trailing arm bushes
And mounted a couple off USB charge outlets into a switch blank, wired to accessory power.
Rear crossmember was looking a bit sad so it got a tidy up
And won an APT fuel tank guard about a week ago, picked it up yesterday. The stock fuel tank guard and plastic tank already carry a few scars so one of these was always on the list. Now just need the weather to clear up to fit it up. 6mm 5005 aluminium, this is a staunch bit of gear!
Post #472377 14th Nov 2015 3:26am
ericvv
X2 that is. I actually was on aulro.com years before I even had heard of def2.net, aulro.com actually contributed to me buying the SVX, but when it became payable, I happily left it to others. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #472379 14th Nov 2015 4:48am
BRE770
Fitted it up today, turns out you can jack the rear of the car off the ground under the fuel tank now, hehehehe
Post #472645 15th Nov 2015 9:33am
Page 5 of 5 <12345
