Home > My Defender > Bretto's new 110 wagon
Page 4 of 5 <12345>
BRE770
Australia 2013 Defender 110 Puma 2.2 SW Corris Grey
Fitted the roof rack last night, what a Censored Censored of a job, especially when its just me and the wife. also picked up the cargo barrier yesterday, will post pics when I get a chance to take a few.
Post #299434 16th Jan 2014 8:55pm
BRE770
2.8 metre by 1.4 metre Front Runner rack
Front Runner access ladder. Always cringe a little when I have to break out the drill and punch a few holes in the new car
Post #300153 19th Jan 2014 12:44am
Cheshire110
Looks good, suits the car well! Cheers, David
Post #300159 19th Jan 2014 1:20am
Don't they do a rack to chassis ladder similar to the Patriot one? It would save on that drilling and also with the more rungs actually makes access easier.
Post #300512 20th Jan 2014 9:14am
BRE770
they are illegal here in oz as they cover part of the number plate. I think the full gutter to chassis ladders look better and serve the purpose better just didn't want the drama.
Post #329603 9th May 2014 10:53am
Limey
Italy
I have to say that I'm jealous of your black number plate, it's so low-key compared to the massive reflective things that we're obliged to wear.
I've got an ancient bike, and they allow that to have black plates with silver letters. I'd love that plate on my 110.
Post #329680 9th May 2014 3:07pm
RockJaw
United States 2013 Defender 110 Puma 2.2 SW Santorini Black
Nice rig mate, its fair dinkum got everything.
Love the e-brake kit especially.
Now all you need for cruising up the Gold Coast is one of those AHMs (Automatic Horny Maker) and you'll be waxed !!
onya Bretto!! ****CENSORED****
Post #329682 9th May 2014 3:17pm
What about fitting a full length ladder on the right-hand side? That's got to be better than that - how do you get onto the lower rung without a separate set of steps; and that's a lot of weight to be swinging off a couple of bolts through the roof.
Post #329715 9th May 2014 5:27pm
BRE770
first up the same weight would be "...swinging off a couple of bolts through the roof..." regardless of wether its full length or not.
If it was put on the drivers side then it would be in the way of the spare tyre when the rear door opens. I've been up and down it more times then I care to think about since fitting, there is no movement in it and no signs of it ever having moved, it feels very solid. Anyway holes are there now so its not getting moved or replaced anytime soon.
As far as getting up to the ladder goes, you just have to open the rear door, then use the factory fold down step and the rear door opening. Its not that hard...
Post #330453 12th May 2014 5:37am
Fair play on the two bolts through the roof panel showing no signs of movement - is there a load spreading plate on the inside?
Post #330477 12th May 2014 7:42am
BRE770
no bolts go through the roof panel its a clamp on the gutter, same style as the roof rack, the only bolts are at the base through the top of the tub where the material is around 3-4mm thick
Post #330483 12th May 2014 8:32am
Krackers
BEE770, I am drawing a lot of inspiration from your posts! I have recently bought a carbon copy of your car, so I am loving all the additions you have made. Nice kit.
Post #336169 6th Jun 2014 11:42am
Krackers
Post #336170 6th Jun 2014 11:44am
BRE770
cheers mate
Post #343131 6th Jul 2014 7:29am
BRE770
Time for celebration. The defender is now a fully fledged landrover. With 12000 kms on the clock it's now developed it's first oil leak. Front swivel hubs, earned it's stripes I guess you could say.
Also bought a cargo barrier for this aaaaages ago, bout 6 months in fact, anyway finally got around to fitting it up couple of days ago. It's an auto-safe unit and seemed to fit pretty good with only minor modifications to the bracketry to make it spot on.
Bit if a crummy pic
And a pic of the big girl hooked up to the camper because I like pics, and the camper has Land Rover mudflaps Cool so it's kind of relevant
Also just ordered a centre silencer replacement section from Britpart, wanted a Terrafirma unit but they are apparently out of stock at the moment with no date for when they would have fresh stock. And also Terrafirma rear corner chequer plate pieces in black to cover up this damage from the mudflap brackets when I bottomed it out in a washout
and lastly a couple of poser pics because i'm a pic whore
Post #355861 5th Sep 2014 10:44am
Page 4 of 5 <12345>
