![]() | Home > Technical > Diagnostics for the Puma. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Updated 16/11/14.
Lorryman - thanks for taking the time
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 ![]() ![]() |
Lorryman, all I can say is thank you...for the time, the effort, and the willingness to pass on your knowledge. Well done. My Defender and travels
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Brilliant
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 ![]() ![]() ![]() |
Has anyone tried this?
http://www.ebay.co.uk/itm/JAGUAR-LAND-ROVE...20f6a1d719 |
Search reveals....
Couple of other threads with a mention....it may be a copy at that price as an extract from one of the threads stated "You just need a J2535 type module like the Mongoose to connect it which is around £400GBP, a suitable laptop and a subscription to IDS for £700GBP via TOPIx. You even get IDS Support to call once you have subscribed to it." Why is your link so cheap and has no subscription charge? http://www.defender2.net/forum/topic30756.html?highlight=mongoose http://www.defender2.net/forum/topic8087.html?highlight=mongoose If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Indeed many owners have issues with commercial diagnostics systems and the latest AS10 ecu version.
I already use a nanocom for years and i was looking for an alternative in order to have all diagnostic options available,pump learn etc. Thanks. Edit I just read your post carefully. There is even a cheaper version(bad copy i think,check the spelling ![]() http://www.carsets.co.uk/wholesale/jlr-mon...tAodokUAJQ Last edited by fatman on 13th Mar 2015 12:55pm. Edited 1 time in total |
I'm not savvy with the diagnostics beyond the use of my basic Scangauge I'm afraid. Nevertheless drop Lorryman a 'pm' he is knowledgeable about all this and would be able to advise accordingly.
![]() Treat every day as if it is your last....one day you will be right!! |
Don't waste your money as it states it will read vehicles up to 2014 when in the Q&A it won't access a 2012 Evoque!!. At the very least you need the Drew Tech Mongoose Pro interface to access most LR vehicles, also the version of SDD included is well out of date. Current version is SDD 141_03_V204 JMTW ![]() |
Rattys Member Since: 02 Sep 2013 Location: Skipton Posts: 14 ![]() ![]() ![]() |
Wow a staggering amount of detail you must have the patience of a Saint, many thanks for investing so much time in reviewing the different products. Ive spent the evening reviewing the posts on the forum and feel that Ive just confused my self totally. We are about to start to travel further a field, away from the normal support or dealers/garages with diagnostic equipment and I want to carry a diagnostic tool with us in case or 2.2 tdci develops a fault. I had settled on the Hawkeye but after reading on of your posts have started to favour the IIDtool, which would you say was the more appropriate for independent overland travel?
thanks in advance, PS I couldn't send a PM as I haven't posted enough, as by searching the forum I usually find and my question and an answer has already been posted. |
The IID tool is a very easy tool to use and works on my iphone 6 and ipad. The 2.2 has coverage for the EMS, IPAC and ABS just now with the 10AS coverage in the pipeline. Drop IID an email as they are very pro active in their design and customer support.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1676 ![]() ![]() ![]() |
Ive had all of the tools over the years and i have to say i thought the old nanocom was better than the MSV-2, its the worst thing ive ever owned and the customer service is terrible. Ive T4 and Autologic and a Vantage pro scope.
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 244 ![]() ![]() |
I have to admit the nanocom original was a leap forword when it first came out, we bought one, I still own a 1/3 in it, but I bought my own evolution after a while.
As I had a MSV from before I liked to use that more in the workshop with bigger screens (eys Im get on now) and sausage fingers, however the evolution is a great in the field tool. I found SDD a trifle confusing and difficult to navigate around, and have not ugraded it for 2 years now after moving on to IID. The MSV gets fired up every now and again as there are things / options I like better there. Do I have a favorite tool, no I don't, the tool box is full of the different tools for different applications. I have never played with a T4, and only saw one in the flesh last year. There will always be new tools appearing each year, each with new bells and whistles as vehicles get more advanced to tools needed to fix them need to follow. With remote diagnostics coming out does this mean the end of these tools, I dont think so. my 2,5 cents Glen "Rafiki" 2007 110 STW - Rolling rebuild. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
I thought I'd post up my thoughts on the Nanocom Evo I've been using for a short while now. I'm a complete amateur DIYer and didn't have a specific problem that needed solving when I bought the unit, just wanted something there for when the gremlins strike. However, since then I've used it a few times.
Firstly, my alarm wasn't arming and I used the Nanocom to easily change some setting in the 10AS and now all is good. ![]() I wanted to see if I could see the cam sensor output. I've had one fail in the past and borrowed a Britpart Lynx to diagnose it. Turns out the Nanocom can't see the cam sensor ![]() ![]() I'm hoping that future updates to Nanocom might some functionality but I don't know how much they will want to narrow the gap to their more pro grade products. 2007 110 TDCi Station Wagon XS |
