Home > Maintenance & Modifications > Securing Ardcase when driving
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
I am looking at options to secure my ardcase to the drivers seat box when on the move and was thinking the Quick Fist could be a viable option with quick and easy means of securing the releasing. Anybody used this or have other suggestions?
Post #456871 21st Sep 2015 5:07pm
ericvv
Post #456896 21st Sep 2015 6:27pm
ericvv
Now that I'm reminded of this, just ordered 2 sets of these Quick Fist rubber tie down belts from amazon.com in USA. Total price including shipping remains well below the Swiss threshold for import VAT, so no other charges here. Even cheaper than if I would have ordered them on amazon.uk or amazon.de.
Just in case of any interest, here is the link to the correct item:
http://www.amazon.com/Quick-Rubber-mountin...belt+38%22
When I will install it for the Ard'case, will see if I only need to use one set (from charliefox post seems the case), or both sets. If only one, I may offer the second one up here.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #456915 21st Sep 2015 7:14pm
Hairysteve
Thanks Eric Thumbs Up
Post #456923 21st Sep 2015 7:26pm
ozy013
Australia 2010 Defender 110 Puma 2.4 SW Rimini Red
Yep, I've used the quick fists on the roof rack, with a home made bracket, for two years now. They hold my shovel and axe, when we go away.
I can't fault them at all, they are exposed to all the elements and still look as good as new. Initially I was told that they may degenerate when exposed to excessive UV. Though on the packaging it states that they are UV treated.
I guess that won't be a problem for you anyhow. Very easy to operate, and a big Thumbs Up from me.
Post #456983 22nd Sep 2015 12:43am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Ardcase can be secured just with a ring/lynch pin on the side of the seat box using the clip for the lid.
It doesn't get in the way unless you have large feet!
Picture in my gallery:
Post #457698 24th Sep 2015 9:48am
Hufflepuff
Ah bought an Ardcase at Peterborough at the weekend, and need a solution like this. Then I just need another solution for the ENOURMOUS key they give you Laughing
Post #457733 24th Sep 2015 12:08pm
ericvv
scotm, not sure I understand exactly how you fix it there. Any more detail?
Hufflepuf, here is my solution for those enormous keys... Not sure it really is what you are after though. Laughing
Post #457754 24th Sep 2015 1:26pm
