Home > Technical > vdo temp reading on a Discovery 200tdi
dioliahary
Hi, I have fitted a vdo water temp sender and gauge to my defender which has a 200tdi Discovery engine in it.
The gauge reading after a run reads 50c, seems a bit low has anyone got a similar set up for me to compare please,thanks h
Post #455680 16th Sep 2015 10:56pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Far too low what sender did you use?? How long was the run and do you know if your thermostat is working ??
Post #455692 16th Sep 2015 11:40pm
dioliahary
Got the sender and gauge as a pair, vdo.
Yes thought so not sure about the serviceability of the thermostat but I changed the gauge to get a more accurate reading as the gauge was getting close to the right hand side of the white block whilst travelling up hills.
Post #455715 17th Sep 2015 8:15am
dioliahary
Sorry forgot the run was 10 min on the road
Post #455718 17th Sep 2015 8:19am
dave18
Couple of things,
Take it for another run but longer than 10mins say 20 mins.
Make sure your heater controls are set to cold and the flaps work and the fan is off. I can drive for 10 - 15 mins and the coolant wont get warm if I have the heater and or the fan is on.
You can remove the stat and then look at it, it should be closed then put it in a container and pour boiling water over it and you should see it open. In your case if the thermostat is broken it will be stuck open
Post #455733 17th Sep 2015 9:28am
dioliahary
Thanks Dave, popped the thermostat housing off and hey presto...no thermostat Surprised Shocked . I got a new one today and fitted just not had time to top up the coolant and test
Post #455944 17th Sep 2015 9:13pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
Hi,
You could always take out a freshly boiled kettle, pop the sensor in it and the gauge should read close to 100C.
Sounds like you've sorted in now though. Thumbs Up
Andy
Post #455948 17th Sep 2015 9:18pm
dave18
Lol well its there for a reason !!!! Atleast you have found out the reason and have a nice easy fix.
Post #455964 17th Sep 2015 10:02pm
dioliahary
Tested and holds steady Max temp 88c ...result
Post #456207 18th Sep 2015 9:14pm
