Home > Puma (Tdci) > Who has lifted the Puma?
Page 2 of 3 <123>
BigMike
Its at the stealer at the moment having the rear door realigned and the seals changed. I get it back tomorrow and if its still light I'll do pics then, if not will have to be weds.
the pics will be self explanatory, but basically they sit inside the standard spring but are quite a bit stiffer. When there is no load in the back they do absolutely nothing, its only when a load is put in that they start to "work". I had them made by Ali Nasser in zagora, morocco - he does/did a lot of the dakar maintenance and mods for people going through there. top guy. If you want something similar, its a case of just chatting to 4x4 retailers/parts people/garages and coming up with something the right length and stiffness. If you're running with a heavy load (like a long overland trip) they're fantastic offroad - when oure go up steep slopes the load just sits down on both sets of springs and there is no kangaroo effect. I;d recommend them, but not for anyone who wont actually use the second spring if that makes sense?
Post #45357 15th Nov 2010 9:03pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Cheers Mike i've looked into getting extra springs in the back but its been hard work as my local independent says you can only get them for the 110s.....So i just passed on the thought but knowing some one else has done this has made me think again the reason i'm asking is i tow everyday and could do with a little extra help back there i'm running discovery HDs on the back at the moment but with the weight i carry it could do with the extra spring...Thanks for your reply Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #45361 15th Nov 2010 9:16pm
BigMike
No problem. If you can wait I'll be in Zagora in April so could always get some for you if I prep him first. But you might want to have a proper look and a drive of mine first.
Post #45363 15th Nov 2010 9:19pm
fekete
Cheers Mike will most probably Go with that...also would like to see the set up.... i'm sure there will be a meet before then and we could sort something out as you will need the measurements.....one more thing is there any rattle or clanging from them ? Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #45367 15th Nov 2010 9:32pm
BigMike
no rattle or clanging. quiet as a mouse. the measurements would be the same as mine wouldnt they? mind you i have polyurethane blocks on the base of mine, i think you'd need to take a look at it.
where in the country are you?
Post #45374 15th Nov 2010 9:46pm
fekete
Cheshire pm sent Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #45377 15th Nov 2010 9:50pm
BigMike
Ok Fek's going to look at mine in person, but for anyone else interested:
front showing block
rear double springs
Post #45508 17th Nov 2010 8:22am
fekete
Thanks Mike...Ive been lurking on the net and found a company that could make me a set up....
http://www.gmesprings.co.uk/4x4_springs.htm NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #45516 17th Nov 2010 9:31am
BigMike
Did you want leaf springs then Thumbs Up
Post #45519 17th Nov 2010 10:01am
fekete
They say on there wab site that they will make one off springs ?
http://www.gmesprings.co.uk/spring_accessories.htm NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #45522 17th Nov 2010 10:10am
BigMike
yeah am winding you up Laughing
Post #45524 17th Nov 2010 10:14am
fekete
LOL Still up for the 24th so i can look and maybe go down your route.....but just been looking round to see what else there is Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #45527 17th Nov 2010 10:21am
BigMike
Hey if you can get it in england then all the better. In fact a mate of mine with a land cruiser has the same thing. I'll ask him where he got his done
Post #45534 17th Nov 2010 10:35am
fekete
Cheers Mike also found these guys
http://www.coilsprings.co.uk/offroad.htm NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #45535 17th Nov 2010 10:38am
BigMike
Sheffield steel. Excellent Thumbs Up
I just swapped texts with my landcruiser mate. Turns out he had his done at the same place I did mine Laughing
Post #45538 17th Nov 2010 10:48am
Page 2 of 3 <123>
