Home > Puma (Tdci) > Who has lifted the Puma?
Page 1 of 3 123>
MK
and by how much?
thanks
MK Puma 110" SW
Post #45128 13th Nov 2010 10:14am
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I did by, 2inches, then put it back to standard. The prop shaft (front ) binds up and will destroy the transfer box bearings. Lots of owners here have had issues with Puma lift and Land Rover won't cover warranty issues caused by lifting them. If you don't change the prop shaft, and its still under warranty, don't lift it.
Allan
Post #45195 14th Nov 2010 5:21am
i tried but my defender is simply too heavy Laughing
Post #45197 14th Nov 2010 6:58am
Allan
Very good Rolling with laughter Rolling with laughter Rolling with laughter
Allan
Post #45201 14th Nov 2010 7:35am
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Why do you want to lift it?
Is there a need or just fancy a change? Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #45206 14th Nov 2010 9:46am
AndrewS
With the D44 bumper and Warn PowerPlant winch bolted to the front, the front sits low so I give my pumas a 2" lift. However in reality the lift ends up being about 1". I also change the front prop with a wide angle one.
TBH the standard prop could be machined with a small grinder to allow a bit more movement in the UJ. 130's have feeling's as well you know Smile
Post #45209 14th Nov 2010 10:41am
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
You did not try hard enough!! Wink Puma 110 SW
90 V8 SOFT TOP
Post #45220 14th Nov 2010 1:24pm
fekete
I have a 2 half" lift with no problems.....still on the standard props no binding Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #45222 14th Nov 2010 1:39pm
Allan
I have an ARB bar and winch, and loads of other bits on my SVX and because of the front droop use 130 Land Rover front springs with OME shocks. I have found this the way to go on the front, and Land Rover Australia don't mind..
I have a draw system and tow a boat and carry lots of weight so on the rear I use hduty springs with dislocation cones and terra firma +2 inch shocks. I removed the sway bars/anti roll bars, and I also have an ARB airlocker to use when it hard work to pull the boat out on the beach.
Allan
Post #45225 14th Nov 2010 2:46pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
2" lift all round, OME shocks and springs, rears on medium rate springs, front on standard rate. No sign of front or rear prop shaft binding. Am told that it can vary from truck to truck whether you'll get a problem with the props and 2" lift - go any higher and more likely. I'll probably go for a double cardon front prop at some stage- probably once the transfer box is shagged Laughing
Post #45239 14th Nov 2010 5:29pm
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
You must focus your strength grasshopper! Mad 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #45270 15th Nov 2010 6:42am
spudfan
Ireland
Before I even attempt to lift the Puma, I always ask the wife to get out first. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #45299 15th Nov 2010 2:48pm
1" From OME
2" Rear OME
Sits nice and Level now
Post #45314 15th Nov 2010 4:54pm
BigMike
2" front and rear. front on cones, rear on blocks with extra internal spring. sits level when fully loaded and still drives like it's empty. aux springs only come into play when heavily loaded. terra firma big bore shocks all round, outstanding.
Post #45317 15th Nov 2010 5:40pm
fekete
Mike any pics of the extra internal spring and what they are cheers Karl Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #45356 15th Nov 2010 8:56pm
Page 1 of 3 123>
