Home > Td5 > Wipers getting stuck
excossack
When I come to wash the windscreen sometimes the washers work straight away sometimes not. But the issue is that the wipers get stuck on the up stroke right in front of my line of vision and then they stay there until either;
They move on their own
I lean around the window and poke the wipers and then the wipers move
Or just enough water gets to the blade to allow them to move.
I have replaced over time;
Park switch
Wiper boxes/spiral cable that moves the wipers
Wiper blades (standard length Bosch ones)
Is this a sign that the motor is on its way out? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #446988 18th Aug 2015 7:12am
Curious problem. Generally wipers stopping like that it down to worn wheelboxes and/or drive rack, but you say that you have replaced them already. When they are worn, the rack can partially unmesh from the drive gear and lock up.
Did you use good quality replacement parts (if it was Britpart I would still suspect that this may be the issue)?
If you know that the drive rack and boxes are good, it does tend to suggest that it may be the motor itself.
Post #447006 18th Aug 2015 8:21am
excossack
I replaced them with Gen LR ones maybe 2014/2013. So I hope its not them.
Is the motor servicable? i.e new brushes etc? The wipers are fine when the glass is wet. Sometimes the washers don't always work on the first press/no noise/water so makes me wonder if also I have an issue with the stalk or washer motor is playing up 1999 Defender TD5 110
Regards
John M0VAZ
Post #447009 18th Aug 2015 8:26am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
The motor is serviceable, but be wary of cheap components...
Much easier, and less hassle to fit a new complete genuine/OEM motor...
Post #447013 18th Aug 2015 8:41am
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Re: Wipers getting stuck
Park switch
Intersteting, I have a similar issue, except, my wipers work fine on intermittent wipe, or slow wipe. But if I put them to fast wipe the motor slows down and feels like something is binding!
I too had recently changed the wheel boxes, admittedly I did not change the cable.
I have not resolved this yet, but I think the wire drive and the carriers pipes need to re-aligned, I can't help but feel that the issue is there somehow!!
Andy
Post #447045 18th Aug 2015 10:43am
excossack
I think its the park switch. When on intermittent the wiper work fine. If I put them onto the slow setting and turn them off mid sweep they get stop!
So new park switch ordered. 1999 Defender TD5 110
Regards
John M0VAZ
Post #447926 21st Aug 2015 7:01am
Little Tom
United Kingdom 2004 Defender 110 Td5 CSW Bonatti Grey
I'd say 99% certain its the park switch, had a very similar problem on mine. Easy to replace, bit of a fiddle as its behind the dash, I seem to recall if you have aircon it can be even more fiddly. Buy genuine parts, I think its about £20 - £30? Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
Post #451788 3rd Sep 2015 12:49pm
rich
England 2004 Defender 90 2.5 TD HT Barolo Black
I have not long done the wipers on the td5 and I found thet the shaft that the wiper bolts to was rusty in the sleve.
This may help in some way its another part to look at
Post #451820 3rd Sep 2015 2:41pm
excossack
Cheers for the info. I am off tomorrow so intend on replacing the park switch and will lube the shafts as well. 1999 Defender TD5 110
Regards
John M0VAZ
Post #451879 3rd Sep 2015 4:36pm
Fossil
United Kingdom 1997 Defender 110 300 Tdi CSW Coniston Green
Might be your motor is rather tired - I had similar thing, fixed by new brushes in the motor, available from url=http://www.s-v-c.co.uk/category/wiper-systems-and-parts/
Post #454145 11th Sep 2015 1:16pm
