![]() | Home > Td5 > Wipers getting stuck |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17729 ![]() ![]() ![]() |
Curious problem. Generally wipers stopping like that it down to worn wheelboxes and/or drive rack, but you say that you have replaced them already. When they are worn, the rack can partially unmesh from the drive gear and lock up.
Did you use good quality replacement parts (if it was Britpart I would still suspect that this may be the issue)? If you know that the drive rack and boxes are good, it does tend to suggest that it may be the motor itself. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5941 ![]() ![]() ![]() |
I replaced them with Gen LR ones maybe 2014/2013. So I hope its not them.
Is the motor servicable? i.e new brushes etc? The wipers are fine when the glass is wet. Sometimes the washers don't always work on the first press/no noise/water so makes me wonder if also I have an issue with the stalk or washer motor is playing up 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
The motor is serviceable, but be wary of cheap components...
Much easier, and less hassle to fit a new complete genuine/OEM motor... |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
Intersteting, I have a similar issue, except, my wipers work fine on intermittent wipe, or slow wipe. But if I put them to fast wipe the motor slows down and feels like something is binding! I too had recently changed the wheel boxes, admittedly I did not change the cable. I have not resolved this yet, but I think the wire drive and the carriers pipes need to re-aligned, I can't help but feel that the issue is there somehow!! Cheers Andy |
I think its the park switch. When on intermittent the wiper work fine. If I put them onto the slow setting and turn them off mid sweep they get stop!
So new park switch ordered. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Little Tom Member Since: 20 Aug 2013 Location: Lancashire Posts: 134 ![]() ![]() ![]() |
I'd say 99% certain its the park switch, had a very similar problem on mine. Easy to replace, bit of a fiddle as its behind the dash, I seem to recall if you have aircon it can be even more fiddly. Buy genuine parts, I think its about £20 - £30? Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 ![]() ![]() ![]() |
I have not long done the wipers on the td5 and I found thet the shaft that the wiper bolts to was rusty in the sleve.
This may help in some way its another part to look at |
Cheers for the info. I am off tomorrow so intend on replacing the park switch and will lube the shafts as well. 1999 Defender TD5 110
Fossil Member Since: 23 Aug 2015 Location: Bolton Posts: 17 ![]() ![]() ![]() |
Might be your motor is rather tired - I had similar thing, fixed by new brushes in the motor, available from url=http://www.s-v-c.co.uk/category/wiper-systems-and-parts/
