![]() | Home > Puma (Tdci) > 2 questions (bumperettes & brownchurch) |
Well clearly they are the last line of defence so you don't reverse into say a wall and smash all you lights.
They can also be used as a step Russell 2011MY 110 XS USW Black |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
That is a poor excuse for bad driving... i have had LR's for 35 years and never bashed a rear crossmember yet. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Maybe so but not everyone is a perfect as you so they like a little bit of reasurance ![]() 2011MY 110 XS USW Black |
CarlW Member Since: 21 Sep 2010 Location: Lanarkshire Posts: 53 ![]() ![]() ![]() |
They look very like the Bearmach versions I've seen MY11 110 XS Station Wagon in Stornoway |
I have them for one reason only, to protect the rear quarters when driving offroad. That said, they are damn useful steps, and they also protect your fuel tank from any moron who might run into the back of you. You talk about bad driving etc, why do you have one of those soft A bars? |
Lots of roe deer up here but i have yet to reverse into one...
Yeah, that soft A bar will help a lot if you hit one
Mine are for pure 'blingety bling bling factor' because I'm worth it, my Land Rover desrves it and I am pleased as punch with them! ![]() Treat every day as if it is your last....one day you will be right!! |
Can't say I've ever seen a roe deer running around with an a-bar on the front. Maybe the deer's a better driver that you red-dot!!! ![]() ![]() ![]() 2011MY 110 XS USW Black |
gav///m5 Member Since: 02 Oct 2010 Location: south staffs Posts: 6 ![]() ![]() |
Has anyone found any rear bumperettes that willl fit the rear of a 2005 110xs which already has a mantec rear wheels carrier fitted or is it a case of modifying the right hand bumperette to fit around the bracket of the wheel hanger ?
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6150 ![]() ![]() ![]() |
I had to modify my rear bumper to fit around the mantec carrier. I think i made a spacer to move it away from the crossmember by 7 or 8mm.
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Miserable old ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5080 ![]() ![]() ![]() |
Soft A-Bars are about your only option for mounting spot lights AND as a side they improve the front protection god forbid you should hit someone... Mike |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I just mounted my 'soft' A bar. I have to say it's not very soft (feels like solid plastic to me - I was sort of expecting rubber).
I guess the 'soft' bit of it is the mounts - they're only 1.2mm steel ![]() + New Defender 110 First Edition |
