Home > Maintenance & Modifications > Side Lights |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5816 |
Hola,
Overtook a 110 last week that had very bright side-lights, but where standard housing (i.e. not an NAS upgrade). Further, the headlights seemed to be usual Wipacs (sorry, this was all gleaned in the rear view mirror). I did some research on line, as I need to buy a replacement side-light and repeater, and was assuming/wondering if: a. These are LED upgrades? (Assumed) b. If anyone has used them? (Wondering) c. Any recommended site/brand/light? (Wondering) Many thanks as always... Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
2nd Sep 2015 11:39am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
If they were "very bright" then maybe not this, but I have run 10W bulbs in Defender sidelights instead of standard 5W 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Sep 2015 11:41am |
alski Member Since: 21 Feb 2014 Location: Belfast Posts: 13 |
I use a set of these
http://www.advancedfactors.co.uk/207-5630-...5659-p.asp from site sponsor Advanced Factors. Very bright (almost brighter than my main beam) - Wipac Crystal upgrade next!! |
2nd Sep 2015 12:13pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
... and also technically illegal.
2nd Sep 2015 12:17pm |
Yes I am guessing that's what they were as they were a sharp, bright white as opposed to just 'brighter' (in answer to Martin/Blackwolf). We only MOT once every two years, so even if illegal it'd only take 10mins to pop them out before an inspection. Do you use them on your repeaters/tail lights as well or just the side lights? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
2nd Sep 2015 1:28pm |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
I like the look of these also Another reason I'm liking these is the fact that I actually prefer the look of the standard LR lenses over aftermarket options. |
2nd Sep 2015 1:33pm |
CE certified - whatever that means - although I did wimp out and change them for MOT last week. 5 minutes to swap so not a big problem. Have only used them in sidelights so far but considering trying the stop/tail combo. |
2nd Sep 2015 1:48pm |
CE certified probably means they're okay if you have a nut allergy.
Going to go for the full whack and do side, tail and repeaters. Then get some Phillip Ice thingys for the headlights. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
2nd Sep 2015 2:02pm |
As an addendum, does anyone with electrical knowledge know if I can do a straight swap with these LEDs for the repeaters/tail/brake lights or whether I would need a relay modification? If so, to 'learn', why would I need one?
Ta Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
2nd Sep 2015 2:53pm |
Indicators require a flasher unit change for an LED compatible one, the rest are swappable. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Sep 2015 3:06pm |
Thanks Martin. Monsieur Le Grenadier
2nd Sep 2015 4:19pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
I had 10w but the plastic cover melted slightly, back to 5w for the vintage candle glow which I actually prefer.. |
2nd Sep 2015 5:25pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Not technically illegal but are ILLEGAL to use in place of a filament bulb.
Do NOT confuse an E mark for a CE mark A CE mark is basically saying it meets basic safety standards. A CE mark can be placed on low voltage equipment.
Last time I looked our vehicles were 12v DC so how does that CE mark conform to the Low Voltage Directive which is for 75-1500 V DC equipment apply to a LED cluster in a vehicle?? Brendan |
2nd Sep 2015 6:22pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
Without wanting to go too far off-topic, just for reference the LVD is only one of many Directives which require the CE mark. As mentioned this lamp doesn't fall within the scope of the LVD. However, it might possibly be CE marked under the EMC (Electromagnetic Compatibility) Directive ie designed to not interfere with a nearby radio / TV.
2nd Sep 2015 6:53pm |
