Home > Maintenance & Modifications > Side Lights
Grenadier
Side Lights
Hola,
Overtook a 110 last week that had very bright side-lights, but where standard housing (i.e. not an NAS upgrade). Further, the headlights seemed to be usual Wipacs (sorry, this was all gleaned in the rear view mirror).
I did some research on line, as I need to buy a replacement side-light and repeater, and was assuming/wondering if:
a. These are LED upgrades? (Assumed)
b. If anyone has used them? (Wondering)
c. Any recommended site/brand/light? (Wondering)
Many thanks as always... Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #451367 2nd Sep 2015 11:39am
Martin
Site Admin
If they were "very bright" then maybe not this, but I have run 10W bulbs in Defender sidelights instead of standard 5W  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #451368 2nd Sep 2015 11:41am
I have heard also of people running 21w bulbs instead of 5w.
It is (or at least it used to be) a legal requirement that sidelight and tailight bulbs did not exceed 5w. Given that the lighting rulebook seems to have been thrown away by the EU, it may be that this is no longer the case.
Post #451373 2nd Sep 2015 12:06pm
alski
Northern Ireland 1991 Defender 90 200 Tdi CSW Cairns Blue
I use a set of these
http://www.advancedfactors.co.uk/207-5630-...5659-p.asp
from site sponsor Advanced Factors.
Very bright (almost brighter than my main beam) - Wipac Crystal upgrade next!!
Post #451376 2nd Sep 2015 12:13pm
... and also technically illegal. Big Cry
Post #451379 2nd Sep 2015 12:17pm
Grenadier
Yes I am guessing that's what they were as they were a sharp, bright white as opposed to just 'brighter' (in answer to Martin/Blackwolf). We only MOT once every two years, so even if illegal it'd only take 10mins to pop them out before an inspection.
Do you use them on your repeaters/tail lights as well or just the side lights? Monsieur Le Grenadier
Post #451410 2nd Sep 2015 1:28pm
need4speed
I like the look of these also Smile
Another reason I'm liking these is the fact that I actually prefer the look of the standard LR lenses over aftermarket options. Thumbs Up
Post #451413 2nd Sep 2015 1:33pm
alski
CE certified - whatever that means - although I did wimp out and change them for MOT last week. 5 minutes to swap so not a big problem.
Have only used them in sidelights so far but considering trying the stop/tail combo.
Post #451416 2nd Sep 2015 1:48pm
Grenadier
CE certified probably means they're okay if you have a nut allergy.
Going to go for the full whack and do side, tail and repeaters. Then get some Phillip Ice thingys for the headlights. Monsieur Le Grenadier
Post #451419 2nd Sep 2015 2:02pm
Grenadier
As an addendum, does anyone with electrical knowledge know if I can do a straight swap with these LEDs for the repeaters/tail/brake lights or whether I would need a relay modification? If so, to 'learn', why would I need one?
Ta Bow down Monsieur Le Grenadier
Post #451445 2nd Sep 2015 2:53pm
Martin
Site Admin
Indicators require a flasher unit change for an LED compatible one, the rest are swappable.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #451449 2nd Sep 2015 3:06pm
Grenadier
Thanks Martin. Thumbs Up Monsieur Le Grenadier
Post #451475 2nd Sep 2015 4:19pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I had 10w but the plastic cover melted slightly, back to 5w for the vintage candle glow which I actually prefer..
Post #451494 2nd Sep 2015 5:25pm
leeds
Not technically illegal but are ILLEGAL to use in place of a filament bulb.
Do NOT confuse an E mark for a CE mark
A CE mark is basically saying it meets basic safety standards.
A CE mark can be placed on low voltage equipment.
Quote:
Background
The Low Voltage Directive (LVD) was introduced at a time when directives contained detailed technical annexes which were intended to supersede national laws. The LVD set out the essential protection requirements, with the relevant technical details being defined by standards-making organizations. This subsequently paved the way for what were to be known as the New Approach Directives.
2. Scope
2.1 The "Electrical Equipment" means any equipment designed for use with a voltage rating of between 50 and 1000 V for alternating current (A.C.) and between 75 and 1500 V for direct current (D.C.). Therefore, this Directive is called often "Low Voltage Directive" which applies to the vast majority of electrical equipment in everyday use. The Electrical Equipment may be placed on the market only if it does not endanger the safety of persons, domestic animals or property.
Last time I looked our vehicles were 12v DC so how does that CE mark conform to the Low Voltage Directive which is for 75-1500 V DC equipment apply to a LED cluster in a vehicle??
Brendan
Post #451511 2nd Sep 2015 6:22pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Without wanting to go too far off-topic, just for reference the LVD is only one of many Directives which require the CE mark. As mentioned this lamp doesn't fall within the scope of the LVD. However, it might possibly be CE marked under the EMC (Electromagnetic Compatibility) Directive ie designed to not interfere with a nearby radio / TV. Thumbs Up
Post #451526 2nd Sep 2015 6:53pm
