![]() | Home > Puma (Tdci) > Leaking seal |
As far as i know it should be one length, sounds like its made up of bits
does it come on a roll in factory and you've got a bit off the end of roll |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Not sure but it's not the first defender Iv seen like it but after the rain we have had it really does come in 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 ![]() ![]() ![]() |
Makes me wonder if JLR employ a team of people dedicated to finding ways of annoying the
Eau02467 Member Since: 20 May 2015 Location: Glasgow Posts: 48 ![]() ![]() |
Mine is the same, need tho change it but think it's a massive job. May try to smear a thin layer of clear silicone over it n see if that helps
I cant believe anyone thinking its ok to have the window seal made up of bits
what year defenders are like this ? all mine have been one piece and any ive looked at have ( not that I make a point of looking at window seals !! ) |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
It's a warranty job. Seal should be one piece.
My TDCI went in for 3 weeks to the body shop and they took the roof off and applied a new seal. 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
It's 2 months old looked at 3.2 tonight which is 08 and that had the same but the seal is about 3mm thicker or not been squashed so much
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Its maddening mine has a join about 2 inches from one end so its in two pieces...the passenger side is about 6-7mm thick but the other end is about 3-4.....is it true it has to be in one piece ..have you got that from landrover?Who ie the bloke on here who represents landrover perhaps i could get the sp from him! |
Part number is FAJ100020
LR one piece. Do a search for it. Have replaced 2 in last year. 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
thanks FM..did you do it yourself?So forthe need for a sub £5 part the landrover
![]() ![]() ![]() Last edited by nitram17 on 19th Aug 2015 12:32pm. Edited 2 times in total |
Yes. Need a couple of mates to hold the pressure on the roof to keep the gap open but after getting retaining brackets off, less than 30 mins on a CSW 1951 80" S1 2.0
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 ![]() |
If you want to "bodge it" try plumbers gold from ever build. It is like silicone but much stronger and can be applied if the area is not dry. It is brilliant stuff. Go for clear of course. I am not trying to sell this myself ( I can but that's not why I'm posting this reply)
http://www.everbuild.co.uk/plumbers-gold You can pick it up from a few places. 110 Hardtop |
After LR dealer repeatedly
![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
Does anybody know whats tha reason for the foam tape in the first place..there must be a better sealing medium out there?
