![]() | Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
Ray, was there enough gap under the headlining to fit in all the layers without making an adjustments to the headlining itself? I.e. You could take it off, put in the deadening and replace? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
With you on this one. I think the best resolution (to have round lights but without them looking too small on the bumper) is to have two pairs. Very smart...... ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Hi, the sound deadening was no problem but I got 7mm closed cell foam and with two layers it's quite tight to get the roof lining back on. I'd recommend getting 5mm closed cell foam and putting one layer over the whole roof and the second layer just on the flat part of the roof but not on the curves at the edge then everything should go back easily. Ray My build thread http://www.defender2.net/forum/topic17615.html |
Thank you ![]() @jimb1978 as soon as I get a decent drive in I'll post up if it's made a difference ![]() My build thread http://www.defender2.net/forum/topic17615.html |
When I put the third light in I changed all three courtesy light bulbs to LEDs, I've just been out now it's dark outside and can honestly say it's transformed!!! No more scrabbling around in the dark to find things. It's so much lighter in the whole car, well worth doing
Something else arrived (it's like Christmas)
![]() Click image to enlarge Theres quite a difference from factory green tint to the new ones. ![]() Click image to enlarge I'm trying to get them fitted today if I can get the time so may post up pics later ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 ![]() ![]() ![]() |
How do you do that? Where do you get the LEDs from? I will certainly want do that. |
I got mine off eBay, plenty like this on the bay
![]() http://www.ebay.co.uk/itm/Land-Rover-Defen...41924a2304 Ray My build thread http://www.defender2.net/forum/topic17615.html |
Got both the windows in and finally gave it a wash but couldn't finish off cleaning as its started to rain
![]() ![]() Click image to enlarge Only a few bits left to get for the outside then finish a few bits on the inside and underneith and then it's save up time to get the respray done and new doors ![]() My build thread http://www.defender2.net/forum/topic17615.html |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 ![]() |
Looking good. How much difference has all the soundproofing work in the rear made?
When I did the bottom half (still some bits to do here and there) it made a big difference, you can have normal conversations with passengers at motorway speeds and even hear the radio
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 ![]() ![]() ![]() |
Now that's a nice looking motor!
Thank you
Next job on the list. I got fed up of un-sticking the turbo actuator and I'm not sure if it's in my head or not but it feels a bit flat going up hills so I'll start with a new turbo
![]() ![]() Click image to enlarge Just need to order a new oil feed pipe and new oil so as not to junk the new turbo when fitting so it'll go on in the next couple of weeks. Ray My build thread http://www.defender2.net/forum/topic17615.html |
