![]() | Home > My Defender > 300tdi 110 Project. |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
Ooh looking forward to this thread
![]() my youtube channel |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
How about full soft top, series doors, repaint it AA yellow
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 822 ![]() ![]() ![]() |
I did consider the soft top but lack of security for the dogs put me off it .....and also would look too American
![]() N |
Explored the bulkhead further this evening .....can't decide if I should repair or bit the bullet and replace with a galvanized one
![]() Pictures below show the worst of the rot. ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Timo Member Since: 14 Jul 2011 Location: Peterborough Ontario Posts: 171 ![]() ![]() ![]() |
This will be good to see come to life. What on earth is tha black tar on thw vents?
Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
Tim looks to me like someone covered the flaps over with a roll bitumen roofing felt , to try and keep the weather out
![]() Will be a pig to remove...another reason maybe to replace the bulkhead. N. |
Browny90 Member Since: 20 Jul 2015 Location: Derbyshire Posts: 183 ![]() ![]() ![]() |
I've seen Bulkheads in a lot worse condition.. really depends on your welding/ Fabricating skills I suppose.. A new bulkhead can be pricey and time consuming..
I opted for a TD5 one I found complete with ancills, dash etc for �500, only had to do a few of the MODs like the G/box tunnel to fit my LT77 because I'm using the TD5 wiper motor, and complete dash so it was a doddle to fit.. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey ![]() |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
The things some people with no skill or knowledge do to their cars beggars belief at times! 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3483 ![]() ![]() ![]() |
Replace it and get it galvanised. More projects come to a grinding halt as people try something that doesn't work and then lose the will.
Will be great once done ![]() 1995 110 300TDI 1995 90 300TDI |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Glutton for punishment! Just started into something much the same myself all be it only 4 years old though with a lot less rust
Didn't get much done this weekend , installed the correct transmission brake and removed the Pto driven hydraulic pump for the winch. Did the flange seal on the transfer box too seen as the flange had to come off to mount the new back plate
Oh and found more holes in the chassis ![]() ![]() Before I know it......it will have turned into a complete re - build ![]() N. ![]() Click image to enlarge ![]() Click image to enlarge |
Oh dear
Ok time for a bit of an update , been tipping away at this as time and funds allow..
Gave the engine a full oil service and fitted new decat Exhaust, while I was at I removed the EGR valve and fitted some nice MK performance Hoses. ![]() Click image to enlarge New Nissans radiator installed and topped up with new coolant ![]() Click image to enlarge New Front shox, springs and Galvanised turrets. ![]() Click image to enlarge |
The replacement bulkhead arrived.... Td5 one off a 06 utility 110, hopefully not too different to the 300tdi one....all in all its in fairly good nick, except for some rust along the top of the footwells....Land rover in their wisdom figured there was no need to brush some seam sealer on this joint ...
![]() ![]() ![]() Click image to enlarge Started into removing the dash parts floor plates etc. ![]() Click image to enlarge Thats all for now Nidge. |
