Home > Puma (Tdci) > Electircal (wiring) questions
Can any provide some advice re the wiring in the rear light area on a 2007 Puma (County DC version)?
Behind the plastic panel in the load area on the NS there are two non-connected thin wires. Behind the plastic panel on the OS there is a similar pair of non-connected thin wires. I assume that these are for the speakers that would be present on a SW?
On the OS, there is also a large connector block with 5 (I think) connectors in it, plus a further pair of quite thick wires in a two pole connector. Both connector blocks are not connected. What are these for? Is there a chance that the latter is a live feed that could be used for something useful?
In the OSR wheel-arch just above the rear crossmember there is also a large non-connected connector block. I seem to recall reading in this forum that this is where the fuel-burning hearter option is installed if fitted, is this what this connector is for?
Finally, does anyone have a copy of the electrical manual for a 2007 Puma? With help from the wonderful contributors to this forum I have a WSM, but an electrical manual woudl be handy.
Thanks.
Post #36629 20th Jul 2010 9:23am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
hi
i belive the bigger connector block is for the two electrics and the twin for Aux power socket, well thats what i have connected to mine. The thinner wires are for speakers.
there is a link in a post on here somewhere about downloading the wiring diagrams
Post #36642 20th Jul 2010 12:16pm
nicks wrote:
hi
Thanks. I am puzzled then why I have a (I believe dealer-fitted) towing socket but nothing connected to the bigger connector! The Aux power socket will be useful; must fit one.
Post #36644 20th Jul 2010 12:26pm
It occurs to me that the large unused connector that is inside the vehicle (behind the plastic panel by the rear lights on the o/s) could be the connector for the rear window wiper, which of course is not fitted to my DC.
Can anyone confirm this? Thanks.
Post #37037 26th Jul 2010 9:58am
mse
Post a picture and ill look through the right manual Mike
Post #37049 26th Jul 2010 12:24pm
Martin
Site Admin
Or let me know the wire colours and I'll see what I can find Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #37052 26th Jul 2010 12:33pm
Merlin
Hi Blackwolf,
Where did you get a WSM?
Post #44413 5th Nov 2010 5:49pm
K9F
Blacwolf,
Dgardel one of our other members posted a link to his downloads some time ago, there is a complete set of wiring diagrams therein. Follow the link:
http://www.defender2.net/forum/topic2239.h...+downloads
Alternatively if you're in my neck o' the woods you can swing by and have a look at my diagrams!
Thumbs Up[/quote] If you go through life with your head in the sand....all people will see is an ar5e!!
Post #44416 5th Nov 2010 6:44pm
Thanks guys, I did get a set of diagrams plus the WSM through the generosity of forum members, and I am now sorted.
My confusion stemmed from the fact that someone had (very badly) spliced a non-fenuine trailer socket harness into the tail end harness, so that the proper trailer connector was not used. Again , through the co-operation of forum members I now have the correct socket wired correctly.
Post #44417 5th Nov 2010 6:48pm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Re: Electircal (wiring) questions
Thanks.
PM sent.
Allan
Post #44505 6th Nov 2010 10:47pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
I've been trying to get hold of the wiring diagrams on another thread today (and the above link was recommended but I've not had much success with the downloads) - could somebody send me a link to an unzipped .pdf??
Much appreciated
Post #44511 7th Nov 2010 12:25am
Allan
PM me with email details and I will send the file.
Allan
Post #44518 7th Nov 2010 7:04am
