Home > Maintenance & Modifications > Puma ignition live - help
scotia
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Trying to wire JW Speaker DRL headlights and spent all day trying to get to the ignition live under the instrument binnacle and failed. Also tried to unplug the heater motor fan to get to the ignition live wire there and failed again (needed this off to know which colour wire is the ignition live).
Can anyone help please?
Post #444557 9th Aug 2015 4:33pm
Dora
What do yo mean by ignition live? If you mean live when the ignition is on it's the white one on the ignition key switch.
I just put a double spade on it and fed it to a triple fuse fuse box which I then connected things like reverse cameras and dash cams.
Post #444563 9th Aug 2015 5:07pm
scotia
Yes live when the ignition is on. I managed to lift the instrument binnacle out of the way and get the white wire off the ignition barrel but could not pull out sufficient length pf white wire to crimp another wire.
Post #444569 9th Aug 2015 5:27pm
munch90
Use a piggy back spade terminal
like this
http://www.ebay.co.uk/itm/25-BLUE-PIGGY-BA...20bba66849
Post #444572 9th Aug 2015 5:32pm
scotia
Good idea - thanks, but will get fully insulated - just need to get cable through bulkhead somewhere now.
Post #444587 9th Aug 2015 6:02pm
munch90
Put tape round anything exposed Thumbs Up
Big rubber gourmets eash side under bonnet , just under bonnet seal
Post #444590 9th Aug 2015 6:05pm
Dora
Yes, that's the sort I used. didn't bother with tape as there is very little exposed once connected up..
Post #444594 9th Aug 2015 6:09pm
scotia
OK thanks for your assistance Thumbs Up
Post #444611 9th Aug 2015 6:49pm
Alien
Australia
If you have not already done the wiring another ignition only source is the feed for the wiper switch.
I used this wire for my recently fitted cruise control.
To get a wire out the bulkhead consider the existing wire plug close to the clutch master cylinder.
I opened a hole up and threaded a piece of solid wire through to then pull the electrical cable back through to the engine bay.
With the instrument cluster removed it's a fiddly but achievable job. Cheers,
Kyle.
Post #444714 9th Aug 2015 10:17pm
scotia
Wire through now. Not going through all that's required to get wire through to the ignition switch again, so going to install a 1 in and 4 out fuse block and take off from that. Like this www.ebay.co.uk/itm/230965752213
Post #444717 9th Aug 2015 10:40pm
