![]() | Home > Maintenance & Modifications > Puma ignition live - help |
Dora Member Since: 12 May 2015 Location: South East Posts: 170 ![]() ![]() |
What do yo mean by ignition live? If you mean live when the ignition is on it's the white one on the ignition key switch.
I just put a double spade on it and fed it to a triple fuse fuse box which I then connected things like reverse cameras and dash cams. |
scotia Member Since: 29 Oct 2014 Location: North Cambs Posts: 96 ![]() ![]() ![]() |
Yes live when the ignition is on. I managed to lift the instrument binnacle out of the way and get the white wire off the ignition barrel but could not pull out sufficient length pf white wire to crimp another wire.
Use a piggy back spade terminal
like this http://www.ebay.co.uk/itm/25-BLUE-PIGGY-BA...20bba66849 |
Good idea - thanks, but will get fully insulated - just need to get cable through bulkhead somewhere now.
Put tape round anything exposed
![]() Big rubber gourmets eash side under bonnet , just under bonnet seal Last edited by munch90 on 9th Aug 2015 6:10pm. Edited 1 time in total |
Yes, that's the sort I used. didn't bother with tape as there is very little exposed once connected up..
OK thanks for your assistance
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
If you have not already done the wiring another ignition only source is the feed for the wiper switch.
I used this wire for my recently fitted cruise control. To get a wire out the bulkhead consider the existing wire plug close to the clutch master cylinder. I opened a hole up and threaded a piece of solid wire through to then pull the electrical cable back through to the engine bay. With the instrument cluster removed it's a fiddly but achievable job. Cheers, Kyle. |
Wire through now. Not going through all that's required to get wire through to the ignition switch again, so going to install a 1 in and 4 out fuse block and take off from that. Like this www.ebay.co.uk/itm/230965752213
