Home > Td5 > Td5 sudden loss of power |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
Sounds like the turbo waste gate is seized up so the ECU is detecting overboost and going into safe mode.
Try WD40 and manually move it back and forth a few times. |
6th Aug 2015 10:36am |
Millsy94 Member Since: 06 Jun 2013 Location: Gloucestershire Posts: 91 |
Ok I'll try that, would that not mean that it'd momentarily show more boost on nanocom?
6th Aug 2015 12:54pm |
Browny90 Member Since: 20 Jul 2015 Location: Derbyshire Posts: 183 |
It could be a whole array of things after a jet wash.. Id try and let it dry out a bit and try again if the waste gate isn't the issue..
Not the best diagnosis technique I know, but if drying it out is the key then give it a try, then if that is the case, you know you have water ingress into somewhere it shouldn't be and can look at better water proofing.. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey 2 years off the road, but getting close to completion now Last edited by Browny90 on 6th Aug 2015 1:14pm. Edited 1 time in total |
6th Aug 2015 1:04pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
I did a similar thing to mine a few weeks ago, had an issue with electrics, if I were you I'd go around it with some WD40 on all plugs, fiddle with the wastegate as MRD says, and if you have one - blow out any water with an airline, check inside the airbox to make sure its not wet too.
6th Aug 2015 1:10pm |
Andyred90 Member Since: 30 Mar 2013 Location: Wantage Posts: 482 |
Unplug the MAF then take it for a drive. If it's runs normally that's your problem solved!
I had the same on mine and the difference is considerable. Good luck |
6th Aug 2015 6:40pm |
Did you get this sorted?
9th Aug 2015 8:46pm |
