Home > Puma (Tdci) > converting hi level brake light to brake and side light
munch90
converting hi level brake light to brake and side light ( so brake light would come on dim with sidelights then bright as you brake )
good idea or stupid
good as bit more visiable
bad people make think your braking
any thoughts
(im leaning towards stupid , but I am bored also )
Post #442747 3rd Aug 2015 2:27pm
Venomator
Leave it as a Brake Light only imhgo - most drivers are already too easily confused... Shocked
Wouldn't be too sure on the legality of such a change either... Question
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #442751 3rd Aug 2015 2:39pm
munch90
think your right
boredom the root of all evil Rolling with laughter
Post #442755 3rd Aug 2015 2:44pm
discomog
Hi Munch 90. if you're bored and want to play around with high level brake light have you thought of installing a flashing centre brake light? This flashes for six times then works as a normal brake light. As fitted to some of the latest Mercedes. Some research says that a flashing brake light reduces the reaction time of a following driver. I think a modulating brake light module is about £30.
Post #442770 3rd Aug 2015 3:24pm
munch90
durite do a kit for making brake light flash
Post #442771 3rd Aug 2015 3:29pm
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
If you want more tail lights maybe fit some to the top corners on the back of your roof?
If I see a red light in the middle, I would assume it was braking..
Plus I think all UK lights have to be CE marked, which means they have been tested to a certain standard, which means modifying them probably invalidates the testing carried out?
Thumbs Up My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #442781 3rd Aug 2015 4:00pm
Browny90
Why would you want your brake lights to flash? Surely you would just look like a knob? Rolling with laughter My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #442782 3rd Aug 2015 4:01pm
gilarion
Why not convert one of these for brake lights Rolling with laughter
http://www.defender2.net/forum/topic37172.html For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #442783 3rd Aug 2015 4:04pm
munch90
with the durite kit the light flashes only under hard braking
we will all look like "knobs" as a lot of all new cars do it as standard and shown to grab the attention of someone about to hit you up the back
Post #442799 3rd Aug 2015 5:07pm
I think you'll find that tail lights have to be matched pairs on opposite sides of the centreline, and a single (or third light) on the centreline is not allowed.
Post #442826 3rd Aug 2015 7:04pm
munch90
blackwolf I think you would be right , ive never seen one in middle
just a thought as you would be more visible , but don't fancy extra lamps up top
brought one of the brake light flashers off ebay , only a fiver and will have a play and see how it looks
Post #442829 3rd Aug 2015 7:28pm
leeds
Vehicle Lighting regulations have not kept up with all modern developments.
One requirement under VLR is that all obligatory lights have to be type approved which basically means E marked these days
Altering a type approved light say by replacing a filament bulb with a LED will invalidate the type approval. Replacing a burnt out filament bulb with the correct wattage bulb is fine.
For any car you need a minimum of two rear position lights as a pair. You are allowed a second pair as well as long as they are in matching positions.
Brake/stop lights on a car a matching pair which are E marked.
Optional brake lights are allowable but must be type approved E marked (high level brake lights)
Now here comes the 'conflicting/interesting' bit!
VLR states
Quote:
Lamps to show a steady light
13.—(1) Save as provided in paragraph (2), no vehicle shall be fitted with a lamp which automatically emits a flashing light.
(2) Paragraph (1) does not apply in respect of–
(a)a direction indicator;
(b)a headlamp fitted to an emergency vehicle;
(c)a warning beacon or special warning lamp;
(d)a lamp or illuminated sign fitted to a vehicle used for police purposes;
(e)a green warning lamp used as an anti-lock brake indicator; or
(f)lamps forming part of a traffic sign.
Now the Durite flashing unit
Quote:
Product Description
Durite 0-743-62 12V emergency braking stop light unit.
Flashes the vehicle stop lights under emergency braking.
The microprocessor control unit,triggered by the inertia switch at deceleration of 6m/s², flashes the vehicle stop lights at 3.5 flashes per second for up to 12 seconds, warning following vehicles of emergency braking.
After 12 seconds or when emergency braking ceases the brake lights revert to norm operation.
ECE approved.
Now where I get confused is that the flashing unit might be ECE approved but that is for the flashing unit.
When it makes the brake light flash is that road legal under VLR?
Does a later EU regulation over ride the older UK VLR?
As for the cheap flashing brake lights on ebay? No mention of E marks!
Have seen the flashing brake lights in action in Asia and not really impressed with them Some of them puplish/bluish.
Brendan
Post #442865 3rd Aug 2015 8:51pm
munch90
A lot of new cars come with brakes lamps that flash as standard , think normally under heavy braking , but i think they flash all lights no just high level
so guessing that the normal 2 lower brakelights act as normal , maybe it doesnt matter about high level as its not a legal requirement
for mot the high level should work , but only if its got wiring to it , as your not allowed to dismantle to check for wiring thats a bit hard to do
example is some vans are fitted with the lense but no wiring and the same van but higher spec will have wiring
since joining eu the regs are a nightmare
look at mots , you check 13pin tow sockets , but not 7 pin , so its ok for a 7 pin to have faults but not 13 pin whats the difference you still got trailer lights out
i brought the lamp controller not one of the whole lamps on ebay , so the lamp will be the same , and controller will be only on high level , lower lamps as standard ( thats if i like look of it )
Post #442871 3rd Aug 2015 9:05pm
Much confusion presently arises from the fact that it is illegal under EU law for the UK to prohibit any vehicle feature which is legal under EU law.
Because the EU allows flashing brake lights, front obligatory lights mounted less than 600 mm from the road, these moronic "steering" fog lights, and so on, all of which are specifically illegal under UK law as written, they cannot now be legislated against by the UK. In effect, it would be illegal to enforce the UK law as written.
This absurd situation makes it sometimes very difficult to know what is, and what is not, actually legal!
Post #442880 3rd Aug 2015 9:48pm
Excellent, now I am a victim of double post syndrome!
Post #442881 3rd Aug 2015 9:48pm
