Home > Puma (Tdci) > 3000 miles old. 3rd breakdown. Won't start. Help! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17209 |
Turn off the passive immobiliser (with a diagnostic tool). Your vehicle will become vastly more reliable.
3rd Aug 2015 12:59pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 677 |
Thats it that fixed it. I can simulate the issue by putting the fob in the cup holder, it then starts once you join them together again.
Thank you all for the advice thats great. im now down to only 2 breakdowns in 3000 miles. Thats much better!! |
3rd Aug 2015 1:06pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 |
The receiver ring is less than an inch from its original position. This is a 2014 vehicle that we've had from new so no, no one has replaced the fob |
3rd Aug 2015 1:15pm |
just sounds like fob or unit problem then
do you have 2 fobs ? |
3rd Aug 2015 1:30pm |
The ring maybe only 1" from it's original position but chances are if it's like mine with an X-Eng barrel lock fitted it'll now be lying flat instead of upright and potentially partially masked by it's new position. The field/signal it emits may not be as strong and the fob may not cut/enter that field as it once did requiring a more 'precise' position to do so? If you go through life with your head in the sand....all people will see is an ar5e!!
3rd Aug 2015 4:41pm |
