Home > Puma (Tdci) > 3000 miles old. 3rd breakdown. Won't start. Help!
Page 2 of 2 <12
munch90
take it the receiver ring is still fitted that normally sits around the ign switch , to fit the x eng you have to move it
possible its too far away
in practice the ring can be a few inches away and still work
is it the oringnal fob , has someone replaced fob with non chipped one , im sure the non chipped ones still work but only on buttons
Post #442707 3rd Aug 2015 11:41am
Turn off the passive immobiliser (with a diagnostic tool). Your vehicle will become vastly more reliable.
Post #442712 3rd Aug 2015 11:59am
Matt110
Thats it that fixed it. I can simulate the issue by putting the fob in the cup holder, it then starts once you join them together again.
Thank you all for the advice thats great.
im now down to only 2 breakdowns in 3000 miles. Thats much better!! Thumbs Up Thumbs Up
Post #442714 3rd Aug 2015 12:06pm
The receiver ring is less than an inch from its original position.
This is a 2014 vehicle that we've had from new so no, no one has replaced the fob
Post #442718 3rd Aug 2015 12:15pm
munch90
just sounds like fob or unit problem then
do you have 2 fobs ?
Post #442726 3rd Aug 2015 12:30pm
K9F
The ring maybe only 1" from it's original position but chances are if it's like mine with an X-Eng barrel lock fitted it'll now be lying flat instead of upright and potentially partially masked by it's new position. The field/signal it emits may not be as strong and the fob may not cut/enter that field as it once did requiring a more 'precise' position to do so? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #442791 3rd Aug 2015 3:41pm
Page 2 of 2 <12
