Home > Puma (Tdci) > Wiper woes.
MarkR
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Wiper woes.
So traveling back from a long run yesterday the wipers stopped working, wouldn't have been too bad if it was just me, but I had the wife and two kids in the motor with me. Weather was horrendous and the motor was running for hours, so took a look today, and the motor is still fine but the wipers don't work. Took the dash off and took a look, disconnected the cable and it has snapped inside the motor, is this something I can buy, or do I need the whole assembly?
I'm prepared to document the whole process in the hope that it will help someone else out, I'm happy to add pics of the whole thing. Thanks in advance guys. All the best
Mark
Post #440328 25th Jul 2015 3:37pm
Rickydodah
https://www.lrdirect.com/DLE000010-Wiper-Rack/
Is this what you're looking for? Thumbs Up I started with nothing and still have most of it left!
Post #440353 25th Jul 2015 8:55pm
MarkR
That's it, brilliant, thank you. I've ordered the original LR part, and have set aside next weekend to do the job. Any one have any tips? I've already removed the wiper motor, how does the cable attach to it? Mine was snapped so have no reference to how it should look, I'm thinking I need to disassemble the motor a bit where the cable goes in, there are some small coach type bolts. I will take some pics, back in a bit. All the best
Mark
Post #440393 26th Jul 2015 8:53am
MarkR
So, here are the bolts that I think I need to undue to get access to where the cable seats?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  All the best
Mark
Post #440402 26th Jul 2015 9:51am
munch90
undo small bolts arrowed , remove cover , remove link between geared wheel and wiper rod/cable lift out old bit of cable . refit
couple of small wahers/spacers etc to watch out for that stick in grease
refit with extra grease
Post #440403 26th Jul 2015 9:57am
RED-DOT
I would also replace the two wiper spindles as they may let go soon. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #440406 26th Jul 2015 10:32am
MarkR
That's great both, thanks. The cable just feeds through the wheel boxes and terminates where at the other end? The dash is back on now, so I can't take a quick look. I've just taken a look at the manual and the drawing isn't that clear, also do I really need to take off the dash, can I just tip it forward abit? I'd rather not mess about with the gear sticks, and the manual says I need to remove them both to get the whole dash off. All the best
Mark
Post #440412 26th Jul 2015 10:41am
munch90
other end doesn't do or connect to anything , just feed cable through from motor end
take wiper arms off before removing old cable and pushing cable through as the spindles need to turn 360 degrees for cable to feed right through
grease cable before fitting
Post #440423 26th Jul 2015 11:15am
pumaxs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Zambezi Silver
As above.
Carry out a general overhaul of everything while you're at it - The parts are relatively cheap.
When my wipers failed, the broken side was fixed under warranty & I paid for the other side, as it didn't make sense to have a mix of new & worn components that might lead to another failure in the near future.
By the way, the tell tale signs, leading up to the failure of my wipers, were that one blade wasn't horizontal when parked, nor was the 'bad' blade aligned with the 'good' blade.
If your wipers are doing this then you might want to take preventative action. '57 Defender 110 XS Station Wagon 2.4tdci
Post #440430 26th Jul 2015 11:26am
MarkR
Does anyone have a part number or a link to the wiper boxes/spindle, as most have said it makes little to no sense to not overhaul the whole thing while the dash is off. It quite confusing with all the past models and I'm not sure which ones to order, I'd rather fit original parts as they have lasted eight years. Thanks in advance. All the best
Mark
Post #440439 26th Jul 2015 11:59am
RED-DOT
DKU500010 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #440444 26th Jul 2015 12:07pm
MarkR
Nice one thanks, all ordered. Hopefully they will be delivered next week, and I can fit on Saturday as the wife is refusing to drive it without wipers, what with all the rain we are having. All the best
Mark
Post #440458 26th Jul 2015 12:41pm
lohr500
Hi Mark, when you fit the wiper spindles, please could you let us know how much of the dash you had to strip down to get to them. Cheers.
Post #440474 26th Jul 2015 2:05pm
MarkR
Yes, I will do a pictorial step by step on this thread. Hopefully it will help others and encourage them to have a go, not much point having a Land Rover if you don't want to get dirty hands hey! All the best
Mark
Post #440477 26th Jul 2015 2:19pm
MarkR
So, more problems sigh...
Wife went to start the truck this morning, and the ignition is completely locked on, when I tipped the dash forward is there a chance that I've done something inadvertently to the ignition and steering as there seems to be something touching the steering down tube thingy too? All the best
Mark
Post #441058 28th Jul 2015 3:32pm
