Home > Puma (Tdci) > Wiper woes. |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
https://www.lrdirect.com/DLE000010-Wiper-Rack/
Is this what you're looking for? I started with nothing and still have most of it left! |
25th Jul 2015 7:55pm |
MarkR Member Since: 26 Apr 2014 Location: Norfolk Posts: 15 |
That's it, brilliant, thank you. I've ordered the original LR part, and have set aside next weekend to do the job. Any one have any tips? I've already removed the wiper motor, how does the cable attach to it? Mine was snapped so have no reference to how it should look, I'm thinking I need to disassemble the motor a bit where the cable goes in, there are some small coach type bolts. I will take some pics, back in a bit. All the best
Mark |
26th Jul 2015 7:53am |
So, here are the bolts that I think I need to undue to get access to where the cable seats?
[URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated All the best Mark |
26th Jul 2015 8:51am |
undo small bolts arrowed , remove cover , remove link between geared wheel and wiper rod/cable lift out old bit of cable . refit
couple of small wahers/spacers etc to watch out for that stick in grease refit with extra grease |
26th Jul 2015 8:57am |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
I would also replace the two wiper spindles as they may let go soon. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
26th Jul 2015 9:32am |
That's great both, thanks. The cable just feeds through the wheel boxes and terminates where at the other end? The dash is back on now, so I can't take a quick look. I've just taken a look at the manual and the drawing isn't that clear, also do I really need to take off the dash, can I just tip it forward abit? I'd rather not mess about with the gear sticks, and the manual says I need to remove them both to get the whole dash off. All the best
Mark |
26th Jul 2015 9:41am |
other end doesn't do or connect to anything , just feed cable through from motor end
take wiper arms off before removing old cable and pushing cable through as the spindles need to turn 360 degrees for cable to feed right through grease cable before fitting |
26th Jul 2015 10:15am |
pumaxs Member Since: 18 Jul 2012 Location: Bath Posts: 180 |
As above. Carry out a general overhaul of everything while you're at it - The parts are relatively cheap. When my wipers failed, the broken side was fixed under warranty & I paid for the other side, as it didn't make sense to have a mix of new & worn components that might lead to another failure in the near future. By the way, the tell tale signs, leading up to the failure of my wipers, were that one blade wasn't horizontal when parked, nor was the 'bad' blade aligned with the 'good' blade. If your wipers are doing this then you might want to take preventative action. '57 Defender 110 XS Station Wagon 2.4tdci |
26th Jul 2015 10:26am |
Does anyone have a part number or a link to the wiper boxes/spindle, as most have said it makes little to no sense to not overhaul the whole thing while the dash is off. It quite confusing with all the past models and I'm not sure which ones to order, I'd rather fit original parts as they have lasted eight years. Thanks in advance. All the best
Mark Last edited by MarkR on 26th Jul 2015 11:45am. Edited 1 time in total |
26th Jul 2015 10:59am |
DKU500010 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
26th Jul 2015 11:07am |
Nice one thanks, all ordered. Hopefully they will be delivered next week, and I can fit on Saturday as the wife is refusing to drive it without wipers, what with all the rain we are having. All the best
Mark |
26th Jul 2015 11:41am |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1316 |
Hi Mark, when you fit the wiper spindles, please could you let us know how much of the dash you had to strip down to get to them. Cheers.
26th Jul 2015 1:05pm |
Yes, I will do a pictorial step by step on this thread. Hopefully it will help others and encourage them to have a go, not much point having a Land Rover if you don't want to get dirty hands hey! All the best
Mark |
26th Jul 2015 1:19pm |
So, more problems sigh...
Wife went to start the truck this morning, and the ignition is completely locked on, when I tipped the dash forward is there a chance that I've done something inadvertently to the ignition and steering as there seems to be something touching the steering down tube thingy too? All the best Mark |
28th Jul 2015 2:32pm |
