Home > Maintenance & Modifications > Garrison outfitters windows kit |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 |
Me too,
Steve |
25th Jul 2015 12:43am |
delab Member Since: 13 Apr 2014 Location: Cornwall Posts: 19 |
You could save yourself a bit of money.... you really don't need to spend anything like as much as that.
I bought the 'Woolies trim', see link http://www.woolies-trim.co.uk/p-1649-window-channel.aspx. Here's instruction on how to fit it too....http://www.nickslandrover.co.uk/defender-side-window-seal-replacement/ The first side took me 45 minutes then 25 once I'd sussed how to do it. Good as new! Last edited by delab on 25th Jul 2015 7:45pm. Edited 1 time in total |
25th Jul 2015 3:17pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5833 |
Did your windows leak and rattle as well?
Cheers for the link, i will have a look when not on my phone. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
25th Jul 2015 6:49pm |
They did... They don't now😊
25th Jul 2015 6:57pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
I cant open them links anyone else hving trouble with them
26th Jul 2015 7:16am |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 |
If you read the link it says with the Woolies stuff the rattle has returned and you cant do ALL the window only the verticle edge which will still allow water in,
Im 50 / 50 on paying £100 for the GO kit or £150 for a new pair of windows |
26th Jul 2015 7:46pm |
I did all but the lower horizontal section where the plastic guttering is located and a year and a half later no rattle whatsoever. I didn't even need to glue the trim in place. The fitting instruction talks of 8 mm trim..... I used the 10mm trim as it is now and was then the smallest woolies did and it totally did the trick. I promise you... you don't need to spend any more, unless of course you want to...
26th Jul 2015 10:48pm |
