Home > Maintenance & Modifications > Garrison outfitters windows kit
excossack
Has anyone fitted a GO window kit to stop rattling windows and also leaking windows?
This annoying feature (rattling windows & leaking windows) is on my hit list this year.
For those that have done it;
Did the kit cure the windows rattle
Did it cure the leaks? (mine leaks in the middle where the middle upright is fitted)
Other than the contents of the kit are there any other bits which need replacing at the same time? (or advisable to?) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #440215 24th Jul 2015 6:57pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Me too,
Steve
Post #440272 24th Jul 2015 11:43pm
delab
United Kingdom 1996 Defender 110 300 Tdi CSW Epsom Green
You could save yourself a bit of money.... you really don't need to spend anything like as much as that.
I bought the 'Woolies trim', see link http://www.woolies-trim.co.uk/p-1649-window-channel.aspx. Here's instruction on how to fit it too....http://www.nickslandrover.co.uk/defender-side-window-seal-replacement/
The first side took me 45 minutes then 25 once I'd sussed how to do it. Good as new!
Post #440325 25th Jul 2015 2:17pm
excossack
Did your windows leak and rattle as well?
Cheers for the link, i will have a look when not on my phone. 1999 Defender TD5 110
Regards
John M0VAZ
Post #440339 25th Jul 2015 5:49pm
delab
They did... They don't now😊
Post #440341 25th Jul 2015 5:57pm
theorangebandit
I cant open them links anyone else hving trouble with them
Post #440386 26th Jul 2015 6:16am
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
If you read the link it says with the Woolies stuff the rattle has returned and you cant do ALL the window only the verticle edge which will still allow water in,
Im 50 / 50 on paying £100 for the GO kit or £150 for a new pair of windows
Post #440512 26th Jul 2015 6:46pm
delab
I did all but the lower horizontal section where the plastic guttering is located and a year and a half later no rattle whatsoever. I didn't even need to glue the trim in place. The fitting instruction talks of 8 mm trim..... I used the 10mm trim as it is now and was then the smallest woolies did and it totally did the trick. I promise you... you don't need to spend any more, unless of course you want to...
Post #440564 26th Jul 2015 9:48pm
