Home > Maintenance & Modifications > Squeeky Trackrod Ends |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Hi Guys,
I have had one of those squeaks I just could not track down for the last few weeks. After a lot of head scratching and wiggling of things I have tracked it down to my track rod ends. They will need replacing as I suspect them to be quite warn and very dry. On searching for a replacement I have found these http://www.ebay.co.uk/itm/260930541464?_tr...EBIDX%3AIT Has anyone used them before? Looks like a great idea and makes me wander why they weren't grease-able from the factory? What do we think? Otherwise will be a genuine replacement item Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
20th Jul 2015 10:05pm |
Anyone had experience with these?
One thing which I have noticed and is bothering me is the lack of a castle nut and pin Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
21st Jul 2015 1:01pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I have these fitted on my Puma courtesy of Gwyn Lewis Sumo bars:
http://www.ebay.co.uk/itm/Defender-90-110-...2a4c67d946 They are larger than the OEM track rod ends and slightly touch the new LR front callipers I fitted, (the bottom bolt that holds the two half's of the calliper together.) No sign off rub wear but I will be keeping an eye on them over the next few months. |
21st Jul 2015 8:34pm |
Nyloc nuts are fine as the nyloc is the secondary fastening.
21st Jul 2015 8:35pm |
nearly everything is nyloc now days |
21st Jul 2015 8:39pm |
