![]() | Home > Td5 > Buzzing EGR solenoids |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Having done this mod myself recently, but not experiencing the buzzing, I can only suggest that you may have blanked off the wrong ends? I certainly don't mean to be anything but helpful, but I found my instructions a bit vague, and I initially took off the wrong pipes, although I noticed before completing.
I'm sure that there are plenty of forum users who will know exactly what it is! Best of luck. By the way, it made a big difference once done. Cheers Will |
jonny2tanx Member Since: 06 Jul 2014 Location: Harpenden, Herts Posts: 156 ![]() ![]() ![]() |
Hi Will
Thanks for the suggestion. I'm pretty sure I did the right pipes - I fitted a kit from the same supplier on my old 110 and compared which outlet I had disconnected on that one. The solenoids on the old 110 are completely silent and you can't feel any vibration on them. On the newer car the vibration is such that I'm expecting to find ladies pressing themselves against the inner wing before too long ![]() |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 ![]() ![]() ![]() |
When I removed my EGR I disconnected the vacuum supply where it connects to the main vacuum line then completely removed the solinoids, it won't bring any faults up and it tidy's the engine bay up abit.
Kind Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Same here, completely unplugged and removed all extra pipes and solenoids Ray
Sounds like a plan but I don't have a clue which pipe is the main vacuum line, and what do you do with the other 2 pipes on each solenoid? ![]() |
JimboD3 Member Since: 09 Apr 2013 Location: Ware, Herts Posts: 55 ![]() ![]() ![]() |
From memory, the main vac hose (rigid, black plastic thing) runs from the vac pump (front left of the engine as you look at it from the front) to the brake servo at the back left of the engine bay - with a T off to the EGR modulators/solenoid things........you will have blanked off the part of the 'T' that goes to the EGR gubbins.
When I removed my EGR, I got a replacement vac hose (from IRB I think) - its a genuine part, made for Td5's that don't have EGR valves..........so it doesnt have the 'T' in it ! Other than the small diameter pipe from the EGR valve to the modulators/solenoid things and one electrical multiplug connector, there's no other connections (apart from the small pipes linking the modulators) - so remove the modulator/solenoid things completely in one piece. Td5 110 HD Hardtop.......not quite standard ![]() |
