Home > Maintenance & Modifications > Load Guard
BigMike
Load Guard
This is my nightmare purchase. I've had too so far, one from paddock and one from britpart, both supposedly to fit a 2010 puma 90 station wagon, but neither actually does. Has anyone fitted one successfully to a station wagon (without bulkhead, just with the bar) and if so where did you get it?
Post #43752 28th Oct 2010 8:50am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
I have an original land rover load guard.
Its the bottom part of the dog guard, i guess someone kept the mesh upper part before i purchased the landy.
My version just has brackets which wrap around the bulkhead bars.
Post #43778 28th Oct 2010 11:36am
BigMike
I think I'll have to get the OEM from Landrover. Supposedly the britpart one WAS the oem, but it's a mile away from fitting
Post #43783 28th Oct 2010 12:05pm
Lorryman100
I Have the OEM one from landrover for my 110 puma. Cost a lot, and was a bitch to fit. But looks good and keeps 3 cocker spaniels from licking me to death! Heres the landrover link for fitting instructions for 90 cargo barrier:
http://www.ownerinfo.landrover.com/extfree...006448.pdf
Post #43802 28th Oct 2010 4:16pm
BigMike
Cheers Brian. Problem is that's the one I had, and it wouldn't fit. I think I'm going to have to take it to the dealer as the fittings on the sides for the bar are miles out
Post #43810 28th Oct 2010 4:37pm
Lorryman100
Mine didn't fit first time either. Some of the fittings were out by as much as a couple of centimeters, so after losing the rag for the fourth time fitted it without doing up any of the fastenings until everything was attached. Then tightened everything up and it fitted perfectly. In the first four attempts I had'nt taken into account that it was a defender and assumed wrongly, that everything would be square. (this is my first defender),Embarassed
Post #43812 28th Oct 2010 5:20pm
BigMike
I sympathise! Trouble with the second one I had was that once the lower half was in position, put in loosely, the top wouldnt go near it. the centres which join the top to the bottom were ok in terms of fit, but the angle of the bottom half was such that the top was about 60 degrees as opposed to vertical. there was no room to manoevre on the lower half, we'd already had to jam it in to get the sod to go anywhere near it. I've pretty much thrown in the towel with it and plan to ring the dealer and say will they fit it for the price of supply. if they say yes, its their problem Laughing
Post #43813 28th Oct 2010 5:24pm
Lorryman100
The reason i fitted it instead of the dealers was that they quoted up to 2 hours to fit at £100 per hour!! Must have been the Scot in me thinking robbing B******s, Ill do it myself!!!!
Post #43814 28th Oct 2010 5:31pm
BigMike
a hundred quid an hour ??? Rolling with laughter
Post #43816 28th Oct 2010 5:56pm
Lorryman100
Taggarts Landrover Motherwell, Labour charge £100 per hour. They fitted Safari snorkel and steering guard which I supplied for £330, cost more to fit than buy Big Cry
Lessen here learned the hard way, get a price first........ then fit it yourself.......
Post #43820 28th Oct 2010 6:30pm
BigMike
I think my local guy (crook brothers landrover - not a dealer) charges 30 quid an hour
Post #43821 28th Oct 2010 6:35pm
RLD
still to much Whistle RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #43825 28th Oct 2010 7:55pm
110SEB
I have an OEM in the 110 and it was a butch to fit. Ended up drilling new holes in the top part to marry up with the brackets in the Alpine windows. There is a useful thread on here about people's difficulties with fitting and their solutions. Try a search Thumbs Up
Post #43829 28th Oct 2010 8:16pm
jst
i have OEM in the 110, supplied and fitted by the dealer when i bought it. worth ££ to avoid the hassle.
as an aside Matfords are £120phr Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #43834 28th Oct 2010 8:42pm
--defender--
United Kingdom 2010 Defender 110 Puma 2.4 HT Zermatt Silver
Bought a Land Rover part, fitted it in about half-an-hour. Just needed to tap out some of welded nuts to clear out some black paint, used for thumbscrews. Fitted like a glove. If it ain't broke don't fix it!
Post #43842 28th Oct 2010 9:16pm
