Home > Puma (Tdci) > Overnight Heater
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Overnight Heater
Just found out that Winter is coming ! Shocked
We've been out camping in the waggon reguarly this year and want to keep on camping over the winter - but had a bit of a shock last week in the new forrest.... first sharp forst of the year..burrr!
My wonderful better half was not too impressed .. so requested some overnight heat next time please!
So what is the best overnight heater for the waggon (110 XS Dormobile) ...... ??
Where can I get said heater for a good price (ie cheap!)
and how easy is it to fit to a puma ..(bearing in mind that I'm a nurse and not a mechy type)
(I hear that ex-BT waggons have heaters fitted and some times are avalible .. anyone done this? ) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #43720 27th Oct 2010 9:23pm
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
do you mean something like this?
http://www.defender2.net/forum/topic2123.html?highlight=webasto 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #43721 27th Oct 2010 9:33pm
wyvern
Hi Johny,
not quite like that as I only want hot air not heat the coolent ... I know that some are fitted just to warm the cab areas....
But interesting to see what else is done ... many thanks Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #43732 28th Oct 2010 5:28am
BigRuss
Re: Overnight Heater
I would say get used to it as the heater in the AHU for the east side of the Heather is knackered!
Just give up your single room on the west side. Whistle Russell
2011MY 110 XS USW Black
Post #43733 28th Oct 2010 5:36am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
wyvern wrote:
Hi Johny,
Take a look in my gallery as i fitted an Eberspacher D2 which is a diesel fired hot air blower the same as BT use in their vans , i also had it on a timer and remote Thumbs Up
Post #43759 28th Oct 2010 9:10am
BigMike
Sonic, where does it tap into the fuel system?
Post #43764 28th Oct 2010 9:59am
Sonic3d
I made a 4L tank for it as you can see in the pic below.
Post #43765 28th Oct 2010 10:04am
wyvern
Hi Russ,,
Tee hee! being the platform medic has one or two bonus points - and a suite of rooms with heaters in is just one of them! Embarassed
Sonic - thats the beasty!
Thumbs Up what do I have to do to get one? is you'rs fitted under the drivers seat as I couldnt work it our from the pictures .... nice tidy intsalation though! Bow down Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #43774 28th Oct 2010 11:13am
BigMike
Very cool set up.
where did you put your intake and exhaust?
Post #43777 28th Oct 2010 11:28am
wyvern
BigMike wrote:
Very cool set up.
Na ... a very warm one I hope! Mr. Green Rolling with laughter Whistle Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #43779 28th Oct 2010 11:38am
AndrewS
Sonics set up was located inside an ally box that was fitted in the rear of his pick up Thumbs Up 130's have feeling's as well you know Smile
Post #43781 28th Oct 2010 11:41am
johnnyturbo2002
wyvern wrote:
Hi Johny,
Sorry about that Chief, misread it. 2008 Defender 110 60 year Edition (sold unfortunately)
Post #43914 29th Oct 2010 7:19pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hello,
I have also fitted a D2 Eberspacher, they are expensive but are very good at what they do. I considered getting a second hand one but after looking around decided its probably best to buy new from a UK supplier to get a 2 year warranty. I did read in the booklets the combustion chamber needs replacing every 10 years so if your s/h one is already 5 years old...
I fitted mine in the cubby box and made a 3 way piece for distribution, 1 x 60mm and 2 x 44mm. The 44mm pipe can extent to the rooftent for winter camping.
The exhaust now no longer clamps to the side of the car exhaust but connects into it for silencing and routing the gas to the rear rather than just underneath.
Worked well this week in Wasdale Smile
Steve
Post #43919 29th Oct 2010 8:53pm
wyvern
Hi Steve,
looks great - thanks for the info - going to go and do some sums & see what I can come up with ... Whistle
I think that I may fit one in the cooker unit at the back of the waggon or under the nearside passanger seat - both are good for electical and fuel connenctions and are able to feed hot air into the living areas easily.
I like the idea of feeding heat into the roof tent - as I may feed heat into an awning for our winter cooking and trips to nothern scandinavia...( funny we were thinking of trips to Morrocco and air conditioning last winter!! Embarassed )
It's a shame as Dormobile offerd fitting one when I had the first convertion on our old TD5 - it was a bit pricy though and we had spent a heap of dosh for the convertion so diden't take it up.
Wink Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #43934 30th Oct 2010 10:15am
Steve B
Thanks Wyvern,
I thought about the rear door too, but couldn't decide how to do the exhaust and with the opening/closing of the door it may fatigue the fuel line/wiring. I like the idea of having it all in 1 box like sonics so you can remove it easily for use elsewhere. Mine is part the way, I would just need to get a separate fuel tank and pulse pump. The cubby box comes out in 5 mins complete with all electrics (if you have the key to unlock it Wink )
Another way would be to remove the gearbox cover panel ( cubby box sits on it ) and turn it into a sunken box, there is room underneath ) very nearly went with that.
Here is the modified exhaust..
Post #43951 30th Oct 2010 3:24pm
