Home > Camping, Caravanning and Holidays > Sankey - Camping Trailer Conversion
Page 2 of 2 <12
smb
Have a word with Chris(Killer) at CSK. He did one last year which he had at the Peterborough show. It looked a really good job Thumbs Up
Post #422118 8th May 2015 9:07pm
RLD
this is the first one i did
then on with the second one[ RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #422226 9th May 2015 2:34pm
RLD
then this one RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #422227 9th May 2015 2:40pm
RLD
not much more to do now RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #428072 2nd Jun 2015 3:15pm
fathaggis
i have one here , i don't know what to do with it now . i would love to get a roofrack on to get the tent on it (any ideas)
sankey 3/4 ton trailer with 110 HC tub on it .. it came with the canvas top
then i finally managed to find a 110 HC ifor williams top for it
how do i get a roof rack on the trailer (fit tent on it )
Post #435944 5th Jul 2015 4:52pm
RLD
make some cross bars and bolt them on then put the tent on them RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #435950 5th Jul 2015 5:17pm
ChrisLandyMan
United Kingdom 2003 Defender 110 Td5 XS DCPU Oslo Blue
Like this, the one i made a couple of years ago Cool
Post #436366 7th Jul 2015 4:36pm
fathaggis
i would love something like yours mate ..... Big Cry wanna trade Whistle
Post #436371 7th Jul 2015 4:46pm
ChrisLandyMan
haha... if you want to build something like it i can send more pics if you like... it just slides off and the trailer can be used
Post #436372 7th Jul 2015 4:57pm
Terryt
Now that's neat ..really like that idea
Terry
Post #436401 7th Jul 2015 7:41pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
^^^ what he says!! Well,done, a neat and simple solution! What did you make the sides from?.. Cheers. Alex 98 300 tdi 90 project
94 Range Rover vogue 4.2 lse
79 911 sc
08 130 double cab utility
Post #436406 7th Jul 2015 8:01pm
ChrisLandyMan
the trailer is just a narrow track sankey with steel box section on the top and the camping unit is made from the same box section as shown below and clad with sheet and ply roof which in hindsight should have been of the steel variety due to moisture buildup
Post #436431 7th Jul 2015 9:33pm
PumaPhil
Wales 2015 Defender 90 Puma 2.2 HT Aintree Green
Can I ask what you used for door seals ChrisLandyman? When I built mine I made the doors out of box section steel clad in aluminium, and the 'doorframe' they close into is also box steel - so I have no return lip in the doorframe to mount a seal (a bit of an oversight when I built it, I should have used L-shaped steel as the doorframe). Can't quite make out how your seals work in the photos, so was wondering if you have a similar set up as me? Thumbs Up
Post #437563 13th Jul 2015 9:52pm
ChrisLandyMan
I had aluminium angle glued to the steel box to prevent galvanic corrosion and originally had rubber P seal that was stuck to the angle which sealed the doors 1992 Defender 90 200tdi Hardtop (rebuilding)
1997 Discovery 300tdi
2003 Defender 110 Td5 Double Cab
Post #437564 13th Jul 2015 9:56pm
PumaPhil
Thanks, sounds like a good solution!
Post #437567 13th Jul 2015 10:08pm
Page 2 of 2 <12
